Any luck with DP4 + TDM
burger
Post by burger »
I had a great sounding mixerless system going with a couple of digi 192s and an Pro Tools HD Accel system mixing and handling audio with my DP4 as a front end. But I have to force quit after every cue. And doing any menial task such as deleting audio tracks or adding a plug in takes forever. I just couldn't stay awake. Is anyone having success with this type of set-up?????
thanks,
b
Dual 2.5 gig G5 2.5 gig RAM. DP 4.52
2408 MK3, Digi 96 & 192. Pro Tools Accel HD 2. Various plug ins.
modular
Re: Any luck with DP4 + TDM
Post by modular »
I have a similar setup and don't have the problems you're describing. Generally I'm running sessions with 30-40 chunks and thousands of soundbites. I've found that keeping the soundbites window closed speeds things up drastically. Perhaps you should try removing your plugins from the DAE plugin folder and add them back one at a time. Something definitely isn't right. Your system should be screaming.
Dual 2.5 gig G5 1.5 gig RAM. DP 4.52, 10.3.8,
Digi 192, 192 Digital, ADAT Bridge.. Pro Tools Accel HD 2. Various plugs and VIs.
DP8.04, Mac Pro 2 x 3.2GHz Quad Core running 10.6.8, 16GB RAM, Pro Tools HD5 with four 192 interfaces,VEP Pro 5 running on custom built PC/Windows 7, Vienna Instrument Pro, 2 x MOTU Travellers, UAD Apollo Quad, Waves 9, Slate Digital, Sound Toys, Spectrasonics Stylus, Omnisphere, Trillian, Ivory, Lounge Lizard, Kontact 5, Guitar Rig, LASS strings, Symphobia 1 & 2, Control 24, 2 x Artist Mix and 1 x Artist Control, Yamaha Disklavier Pro plus too many other VIs and plugins to list
burger
Post by burger »
Modular,
Thanks for the reply. I'll keep pluggin' away at this a little longer. I'm curious about one thing. When you have so many chunks working inside of one session. You have to turn back on all your automation each time you add a new chunk to a session is that correct??
b
modular
Post by modular »
Originally posted by buns:
Modular,
b
Buns,
I'm not sure what you mean by "turn back on all your automation'.
