I just installed ethno instruments, using amd athlon xp 2600+ with cubase sx 3.1 as my host controller. Every thing is working fine until I try to drag and drop a loop, seems that the only loops are audio and when I create an audio track and do this every thing freezes up and I have to CTRL ALT Delete to get out of the program and re boot the computer because it changes to asio multimedia drivers from asio lynx L22 drivers that I use and cannot switch back unless I re-boot. Also I cannot figure out how to drag and drop a MIDI loop, they all seem to be audio when I click on the drag and drop box, but they do play as a loop when I preess a key on the controller and record them on a MIDI track
Bill Semanek
ethno instruments
drag and drop
I have figured out how to move MIDI loops, not really a manual guy, found the answer on this forum, but I still have the freeze problem when draging an audio loop.
Bill
Bill
I was getting very frustrated when this feature wasn't working in Cubase 4. All I did was change the import settings so it never popped up. It automatically converted and copied.
Worked like a charm.
Hello everybody. This is my first post.
Cheers
---Adam Wrzeski
Cheers
---Adam Wrzeski
Cubase 4 + Ethno Instrument + 2408 MkI PCI 324
