DP 11.3 with OS 14.3 Sonoma and Superior Drummer - Superior Drummer not loading
Today I upgraded to Sonoma 14.3 and now Superior Drummer will not open in DP 11.3 and generates an error message (see attachment). Has anyone else experienced this with either Superior Drummer 2 or 3? Thank you.
- Screenshot 2024-01-31 at 3.47.27 PM.png (87.83 KiB) Viewed 490 times
MacBook Air M1 2020 w/ OS 14.3 with 16 GB of ram, external SSD, DP 11.3, M4, WaveLab, Keyscape, Omnisphere II, Trillian, Superior Drummer, Numerous VSL instruments, Kontakt etc.
Re: DP 11.3 with OS 14.3 Sonoma and Superior Drummer - Superior Drummer not loading
I have Superior Drummer 3 on my Mac Studio running Sonoma 14.3 and I’m almost certain it works. Not in the studio right now. Won’t be till later tonight, but I will double check. Sounds like it may be something specific to your system, unfortunately.
Thank you very much for your reply, James. I have been using superior drummer 2 and that appears to be the problem. I finally upgraded to superior drummer 3 and now everything is working fine.
So thank you very much for confirming that would work and I think the problem is superior drummer 2 which is just not being supported anymore by toontrack. Thanks again, James I really appreciate your help.
That makes sense. I’ve seen similar errors and that was usually a case where the plug-in was not Apple Silicon native and DP tried to load it using Rosetta and it didn’t work.
