Hi,
I see some ancient posts on this with no answer for me.
After working on this porject on this Mac with no updates, upgrades new software or plugins etc etc - I NOW GET AN ERROR MESSAGE everytime I open the file. (see attached screenshot)
I just saw someone else posted here recently - with no answer that applies to me. There are no plugins failing to lad at startup of DP.
A hint?: When I turn the Mixer Mode off and back on, the message reappears...haunting me...
Thanks in advance for any help!
What Does This Error Message Mean?
- DP9 err msg.png (30.81 KiB) Viewed 454 times
Re: What Does This Error Message Mean?
Hmmm... DP11 here so not totally sure. I'm really not sure what that code means. Probably only MOTU knows for sure. I can't remember ever having a problem turning Mixer Mode on and off, but I should try on some projects and see.
I think it's still possible to have a plugin cause problems even if it loads at startup.
One thing you could try is sort of an old standby for DP users: create a new project and use the "Load..." command to load the chunk from your project giving you a problem into the new one and see if that helps. Many times, that will work.
That's not a hint. It's what is happening. See if you are skipping a step.A hint?: When I turn the Mixer Mode off and back on, the message reappears...haunting me...
https://motu.com/techsupport/technotes/tt_mixmode
