I recently bought a XLR Mic for my MOTU M4 and everything worked fine for the first minutes.
Then the input just drops to 0 and comes back after some seconds to minutes...
I feel like the firmware is faulty? I'm o the latest 2.02. Is there a way to downgrade the firmware, for testing purposes?
I made sure to exchange the mic, tested it on a different pc , switched inputs, also tried USB-C to USB-C, different XLR-Cables.
Doesn't matter it just drops randomly.
I guess I have to return/exchange the unit? I'm just curious if anyone else might have experienced this?
Mout M4 Input drops?
Re: Mout M4 Input drops?
You don’t say how you are powering the M4. Bus owner, yes, but what’s the source? Is it battery from your PC, a desktop, a powered UBB hub?
If the unit is not at fault, that’s really the only logical source of the problem. If your PC is a notebook, you may require a powered hub in the chain.
