DP10 rewind to start each time
Is there an easy way to have the playback start from where it first started out from each time I hit the space bar? I'd like it to rewind to that spot if I hit space, and then playback from there if I hit the spacebar again.
- FMiguelez
Re: DP10 rewind to start each time
Use F1. That sets the rewind point at the current wiper location, even during playback.
You can turn this off/on with the numbers key pad 9 and 8 (I think).
I suggest you check out the other function keys. Quite handy stuff in there
Thanks! I also had to enable the Auto Rewind in at the lower-left of the transport section, so that and using F1 worked for me.
