CueMix DSP EQ render master bus???
- Primary DAW OS: Windows
Hi,
I was wondering, how can I render the DSP Fx such as the EQ integrated in MOTU 828x in CueMix?
I want to use this in the main output of my DAW (Cubase 9.5) ... and also could be good to know if there is a way to use in a group channel from Cubase?
In simple words, I want to use as part of the mastering chain or as part of my mixing process... is it possible?
Re: CueMix DSP EQ render master bus of DAW???
wow... this forum seems to be very active...
Maybe nobody does this.nordlead26 wrote:wow... this forum seems to be very active...
That said, if not possible in software, you could loop back using ADAT ports. Properly routed, this should enable you to accomplish your goal.
PS: Flies with honey, remember?
Re: CueMix DSP EQ render master bus???
You will probably find what you want in the CueMix manual under "return channels".
So is a fact this DSP MOTU FX cannot be used in any software without looping back the ports?HCMarkus wrote:Maybe nobody does this.nordlead26 wrote:wow... this forum seems to be very active...
in such a case seems to be a pretty wasted features and it would be disappointing...
there is no page or section pointing to "return channels"bayswater wrote:You will probably find what you want in the CueMix manual under "return channels".
https://cdn-data.motu.com/manuals/thund ... al_Win.pdf
It appears in mine. And in this one on page 3
https://cdn-data.motu.com/manuals/firew ... _Guide.pdf
bayswater wrote:It appears in mine. And in this one on page 3
Uhm ... but yours is MicroBook II, this feature is supposed to be there...
https://motu.com/products/motuaudio/mic ... ixing.html
On 828x some adjustments should be made if possible... and I don't know if it's possible without wires...
I don't have a micro book. I have two other MOTU units (no longer in regular use). I would have thought this is a cuemix feature, since it has no hardware aspects. It just publishes the name of a virtual input. If there is no virtual input, you'd have use a physical input.nordlead26 wrote:bayswater wrote:It appears in mine. And in this one on page 3
Optical cables are not wires.nordlead26 wrote:bayswater wrote: I don't know if it's possible without wires...
English barrier... translated in Spanish wires and cables means the same thing... BUTHCMarkus wrote:Optical cables are not wires.nordlead26 wrote:bayswater wrote: I don't know if it's possible without wires...
I was talking about TRS multi-conductor cables, not optical....
to add a little more to your comment because was interesting:
Different uses of Wire and Cable
Use of Wire
A wire is used to carry electricity, to bear the mechanical loads, to transmit telecommunication signals, for heating jewellery, clothing, automotive or any industrial manufactured parts like pins, bulbs and needles.
Use of Cable
A cable is used for power transmission, for telecommunication signals or to carry electricity.
https://finolex.com/whats-the-basic-dif ... nd-cables/
