Media Composer audio export
Hi all,
A client of I told me that there's no more omf export in the new Avid Media Composer.
Is there a solution for Avid MC to export for mixing with DP8 ?
Best regards
Christophe
Best regards
Christophe
Re: Media Composer audio export
That might be a better question in a video centric site. I'm not sure many, if any, here are fluent in Media Composer.
- Primary DAW OS: Windows
I am sure you found out MC 7 does export omf
DP10
Asus 490a, Win 10 pro,
Intel Core i7-10700K Comet Lake 8-Core 3.8 GHz LGA 1200
Samsung 970 EVO PLUS M.2 2280 Audio & sample drives
16G ram. MOTU 8A USB3-Thunderbolt
- djwizprod
AAF should be available and works perfect
MacPro8core28GB~OS108.5~DP9.1
PT10~MACH5~Symphonic~Reason~Symphobia~NIKOMPLETE~StormDrum2+3~EWSilver
MiniCore2duo2GB~VirtualVTR~TASCAMDM4800surround~2408MkIII~WAVESBroadcast/Surround360/NPP/VoxRider/GEQ/L316~UAD2DuoPCIe+Satellite~1176/LA2A/PulteqPro/Fairchild/SSLBuss/Lexicon224/Dreamverb
IzotopeRX5/Ozone7/StutterEdit
UA6176~U87~TLM103~AKG414~MKH416~MKH50~DPA4011Apair/COS11D~QuickTime7Pro/FinalCutProX/MackieHR824/624/HRS120~TelosZephyrXstreamISDN~SourceConnectPro
http://www.ozonesound.com
djwizprod,
Can you please tell me how you open AAF files in DP? I'm running DP 8.06 and am trying desperately to open an AAF exported from MC and DP keeps crashing. What's your secret?
Any tips/advice you could give me would be greatly appreciated!
DP 9.52, MachFive 3, MX4, Kontakt5, Omnisphere, PLAY, 828mk3 Hybrid FW-USB2, 8-Pre, MIDI Express XT, Mid-2012 MacPro 2 x 3.46 GHz 6-Core Intel Xeon, 64 GB RAM, Graphics Radeon RX 580 8192 MB, OSX 10.14.6.
- djwizprod
Typically I simply open the chunks window, and drag the AAF from where ever it is on your system i.e. desktop. DP should do the rest from there. I have had issues with AAFs when the audio is embedded, seems to work best if you export the AAF with an audio folder of the wav or aiff files vs embedded. Hopefully that helps? I too am running 8.06 Mac OS X 10.8.5. I had upgraded to 10.9 Mavericks but had way too many issues with DP and everything else on my system. 10.8.5 is solid with DP 8.06.
Thanks for the quick reply djwizprod!
The steps you described are exactly the method I've had success with when opening OMFs. But of course now OMFs are becoming obsolete (according to the editor I'm working with). The AAFs I can't open do have embedded audio, so I'm trying to get the editor to export a new AAF with separate audio, but haven't received it yet.
And just fyi, I'm running OSX 10.7.5.
Any other thoughts or suggestions?
djwizprod,
Would you mind sharing the steps you followed to downgrade from Mavericks to Mountain Lion? I'd like to know how to do this.
- djwizprod
Unfortunately... there is no magic way to do it, at least that I found. Initially I had found a step by step procedure using time machine and some other command line stuff, but it didn't work. I literally just re-built my system, re-installing everything!
