DP crashing when click/drag selecting
darrell
Post by darrell »
Hi all,
I'm 'reviving' an older post I made, with a little new information. The problem persists.
This is a problem that has developed, currently with a MIDI track only, where the project had been working fine up until now, and then appeared 'all at once.' All are MIDI tracks, with MIDI assignments to Eastwest Platinum orchestra, a typical setup for me. When I select a group of MIDI notes (always in Quickscribe window, almost always in Tracks & Sequences) DP immediately crashes. I have not done anything out of the ordinary as far as setup or unusual plugins, etc.
In my original posting it was suggested (thanks, Mike Halloran!) I add more RAM, due to the possibility of a memory leak, which I did (16 GB to 64!), but nothing changed. Workarounds are tediously slow, and any additional help would be greatly appreciated.
Using DP 11.21, 2020 iMac running Ventura, intel chip.
