Dear Motu forum,
I am working on a 3d audio installation in nuendo using a 24ao. I am in the process of transferring the files to a joeco blackbox. I have multiple buses coming out of nuendo some of which use the same output. What I want to do is record the individual channels coming out of the motu (but in the box) so routing 24 channels internally so that I then have 24 individual mono files I can just transfer onto the joeco player. I have done this with the matrix routing menu before but a long time ago and I have forgotten how I did it! Could someone kindly explain the steps required to do this? Thankyou.
Recording multichannel outs on 24ao
Re: Recording multichannel outs on 24ao
Use the pro MOTU Audio Control Routing Matrix to set up I/O as you require.AugustineL wrote: ↑Fri Jul 08, 2022 3:57 am Dear Motu forum,
I am working on a 3d audio installation in nuendo using a 24ao. I am in the process of transferring the files to a joeco blackbox. I have multiple buses coming out of nuendo some of which use the same output. What I want to do is record the individual channels coming out of the motu (but in the box) so routing 24 channels internally so that I then have 24 individual mono files I can just transfer onto the joeco player. Could someone kindly explain the way to do this? Thankyou.
Or do it all within Nuendo.
yes I know you can do it in the motu matrix, what I am asking for is a more detailed description of how exactly. You cannot do this in nuendo 7 alone (though you can route the motu into record tracks in nuendo, I've just forgotten how I did it?)
Basically, it's just the 'From Computer' inputs gets routed/connected to the Analog outputs in the Pro Audio Control matrix. You would select those outputs for your buses in Nuendo. You most likely would have to define those buses if other than mono in the Nuendo output setup - I'm not familiar with Nuendo, but that would be my process for DP.
DP 11.31 PT 2024.3 VEP 7.x with various VIs
