Hi
I have Motu 4 , front two mics are OK but the back side the instrument input signal is too low
What can I do?
Motu 4 instrument input signal is low
- Primary DAW OS: Windows
Re: Motu 4 instrument input signal is low
If you're referring to the M4, the issue is that those are not instrument inputs; they're -16dBu Line inputs. Even the first version of the M4 brochure was wrong on that. Only keyboards with line level outputs can drive them. Despite the fact that many of us here do own such units, most keys etc. do not.harmonicaman wrote: ↑Mon Feb 21, 2022 10:06 am Hi
What can I do?
You need a DI of some sort.
I like the Morley MLLS 2-channel Line Level Shifter (was the Ebtech LLS 2) and the Radial J+4
https://www.sweetwater.com/c957--Direct ... 2high&pn=2
Many other recent threads on this subject including these:
viewtopic.php?f=14&t=69371&p=587103&hil ... ch#p587103
viewtopic.php?f=3&t=69797
Do you mean this ?
https://www.amazon.com/Morley-MLLS-2-ch ... B08NQ1SMTJ
Will it work with my Motu 4 ?
Do I need to connect that to another USB port too?
Do you mean this ?
Thanks in advance
Yes, Yes and Noharmonicaman wrote: ↑Thu Mar 31, 2022 11:48 am Thanks
Do you mean this ?
That is a simple 2-Channel step up (or step down) transformer. It is quiet, passive and very good. The +4 jack goes to the M4 and you plug your keys (or CD/Tape player etc.) into the -10 jack.
The transformer has excellent low end/bass response as all good ones do. Cheap transformers don't give you adequate low end response.
Here's the instruction sheet:
https://morleyproducts.com/wp-content/u ... 070717.pdf
You can use either TRS balanced cables or an XLR-M to TRS going into your M4. The jacks are parallel so it makes no difference which you use but TRS–TRS cables are ubiquitous and inexpensive. The M4 wants a balanced in. Something like this will be fine:
https://www.amazon.com/SEISMIC-AUDIO-SA ... ref=sr_1_4
The -10 jack can take anything. Balanced/unbalanced input cable doesn't matter to the MLLS-2.
Amazon is a good place to buy because of their 30 day return policy. If the output level isn't enough for your situation, you will want an active 2-channel DI instead.
