Most realistic strings legato
Hello folks,
In your opinion what is the best string library especially when it comes to legato realistic passages.
I am not satisfied at all with the East West Gold orchestra...I am not sure if the hollywood strings will be different, but what I have now sounds so synthesized.
When I upgrade my studio to DP 11 and mac miniM1 chips etc I will definitely try the East west comoser cloud but is there any other library that you tink is very realistic?
I have no problem with every other patch (staccato, marcato, tremolo...they all sound great) but the legato sounds...
Thank you.
Thank you.
Mac Pro 2X 2.66 GHz Dual Core Intel Xeon, Snow Leopard OS X 10.6.8, 13GB RAM/ DP 7.24/ Plogue Bidule/SWQL Symphonic Orchestra (Gold),Hollywood Brass(Gold), SWQL RA, SD2, Symphonic Choirs/KONTAKT 4, Cinesamples Hollywoodwinds
Re: Most realistic strings legato
Always the challenge. I like using a breath controller for dynamics, but for legato passages it is all about how the notes connect. And that is a challenge when it comes to sample based instruments. Although the static sound of modeled instrument is often less realistic than sampled, they present superior connectivity. You might like to look into the products from Audio Modeling and Sample Modeling. They are really fun to play!
This was done using LA Scoring Strings (LASS). I downloaded it in 2010 so it's been around a long time. It was the first string VI demo that I really liked. Unfortunately, it's less than 3 minutes—can't find a link to the full length version that I have.
https://soundcloud.com/iain-hemstock/la ... uel-barber
If I was doing something that lush, I'd be tempted to pay the $399. They have so many versions, nowadays, so it's hard to tell what I might like..
https://www.audiobro.com/ab-store/
Hi HCMarkus,HCMarkus wrote: ↑Mon Nov 01, 2021 10:02 am Always the challenge. I like using a breath controller for dynamics, but for legato passages it is all about how the notes connect. And that is a challenge when it comes to sample based instruments. Although the static sound of modeled instrument is often less realistic than sampled, they present superior connectivity. You might like to look into the products from Audio Modeling and Sample Modeling. They are really fun to play!
Thank you. What do you mean by "it is all about how the notes connect". I am a pianist and I know well how to play smoothly connected notes but strings sound horrible...Is there a specific technique or something you need to do? Does it only have to do with the recorded sound of the library since I am playing a true legato??
Hello,mikehalloran wrote: ↑Mon Nov 01, 2021 10:54 am This was done using LA Scoring Strings (LASS). I downloaded it in 2010 so it's been around a long time. It was the first string VI demo that I really liked. Unfortunately, it's less than 3 minutes—can't find a link to the full length version that I have.
Thank you.
I wish there was a sample where it shows fast legato strings. I am not sure how although sampled (real) sounds they sound so unrealistic. I find no explanation...
I think part of the issue is release times. If you play a note and let go, you don't want the note to chop off too quickly. But if you play a legato passage you really need to transition between pitches with little or no overlap. So you need legato-aware release times. Of course, there are other factors that go into realistic legato (like portamento, etc.). It's not just strings, many virtual instruments show some weakness in this area.
The difference is… you are playing a keyboard, not a cello or violin. No sliding from note to note. No bow. None of the subtle elements of a real instrument, ever changing and specific to the instrument. Your keyboard technique may be fantastic, but you’re still playing a keyboard.
Samples are great for recreating a single notes. But how that note is connected to the next is what makes legato sound like legato. Programming a sampler to do this realistically… not an easy task. That’s what I love about the modeled strings. They play like an instrument, not like a picture of one.
Thank you! What do yo mean by "modeled strings"?HCMarkus wrote: ↑Mon Nov 01, 2021 12:42 pm The difference is… you are playing a keyboard, not a cello or violin. No sliding from note to note. No bow. None of the subtle elements of a real instrument, ever changing and specific to the instrument. Your keyboard technique may be fantastic, but you’re still playing a keyboard.
The amount of work that goes into something like this is not immediately apparent. I think a lot more is going on than just a breath controller. I use pedals, two wheels and lots of automation with SWAM solo strings, and I can't even come close to these examples. A very capable VI for sure, but a LOT of work.
828x MacOS 13.6.7 M1 Studio Max 1TB 64G DP11.31
This is exactly my point. If there is no library that can give you realistic sounds for the strings and you have to go through so much work, then why to spend a whole bunch of dollars in a new library.cuttime wrote: ↑Tue Nov 02, 2021 10:29 amThe amount of work that goes into something like this is not immediately apparent. I think a lot more is going on than just a breath controller. I use pedals, two wheels and lots of automation with SWAM solo strings, and I can't even come close to these examples. A very capable VI for sure, but a LOT of work.
And also, I wish someone was showing in YouTube or in this forum what kind of "work" it needs, and how they tweak the sliders for the volume? expression? etc?
It seems so much work and complicated work to go through this. I wish there was one library that could give you this sound without having to do all this...
The amount of work going into those is not surprising. It would be MORE surprising if those results were achieved with AI, etc.
I guess we should all expect that if you want very realistic/satisfying results, then there will be more up-front work on getting the right performance and then editing to get the desired result. And that would/should be the case with any library.
That said, there is quite a bit a library designer can do to reduce the artificial sound of various aspects of the VI.
Is there any youtube video or anything in this forum that is worth reading it to learn how to do this?stubbsonic wrote: ↑Tue Nov 02, 2021 1:17 pm The amount of work going into those is not surprising. It would be MORE surprising if those results were achieved with AI, etc.
I will do my research now, too!
Thank you so much for your time though!
