When I highlight the stop and type in a measure number the format changes to real time before I hit enter.
I don't why or how to change it back.
Memory Cycle start / stop format changing
Lenovo Yoga i7, 16RAM, DP 10.11, Waves analog modeled plug-ins, AmpliTube, Shreddage 3 Jupiter, Mackie HR824 Mk1, Tobii Eye gaze mini.
Yes, I do everything using only my eyes. #ALSsucks
Even when I'm new school I'm old school.
Re: Memory Cycle start / stop format changing
I started a new project and copied everything in and it still does it. So I started another new project and copied things in one at a time testing as I went. I found the culprit to be a MIDI track. I had exported the MIDI track and dropped it into the new project. I then copied and pasted to new track and then exported it. Same problem.
What else can I do?
Why on earth is a MIDI track affecting the memory cycle format?
I need measures not minutes/seconds. Grrrr...
What else can I do?
- FMiguelez
Press Option-command-T to get the Time Formats window. Click on Measures under Time Display and set the rest of the relevant stuff as desired.arsis wrote:I started a new project and copied everything in and it still does it. So I started another new project and copied things in one at a time testing as I went. I found the culprit to be a MIDI track. I had exported the MIDI track and dropped it into the new project. I then copied and pasted to new track and then exported it. Same problem.
What else can I do?
Does that help?
Yes! Thank you! I was searching the manual but hadn't found that window.FMiguelez wrote:Press Option-command-T to get the Time Formats window. Click on Measures under Time Display and set the rest of the relevant stuff as desired.arsis wrote:I started a new project and copied everything in and it still does it. So I started another new project and copied things in one at a time testing as I went. I found the culprit to be a MIDI track. I had exported the MIDI track and dropped it into the new project. I then copied and pasted to new track and then exported it. Same problem.
What else can I do?
Does that help?
