Hi everybody
I imported audiofiles from a CD into DP 4.51 via the soundbites window and want to drop them into Mach5.Mach 5 will accept all other soundbites I created in within DP for that project,but simply does not accept the soundbites I created from the CD import.Is there a problem with AIFF format,do i need to change some settings or bounce those soundbites before M5 will accept them??
CD imported samples not supported
Re: CD imported samples not supported
I bounced the tracks to mono and then I could drop them into M5.Why wouldn't it accept the stereo files?
I've been able to drop stereo AIFF files from the desktop (and/or my hard drive) straight into M5, forgoing the soundbite window. Try it; see if it works for you.
