Connecting DP and JACK2
loneproton
Post by loneproton »
Hi all,
I recently bought an mk5 and I'm trying to set up DP to fit my setup. Since I use MAX and Rekordbox often, I want to be able to route them internally to DP so that I can use it for mixing/mastering, and then send that to my monitors. JACK2 seems to be the most common way to do this but I've been having a lot of trouble getting DP to cooperate with JACK, as the daw constantly crashes, and even when tecnically working it distorts the sound beyond usability, as if like the buffer size wasn't enough. Has anyone got JACK to work well with DP, or is there a better alternative for what I'm trying to do?
CharlzS
Re: Connecting DP and JACK2
Post by CharlzS »
Haven’t used Jack, but have in the past used VB Audio apps. They have VB Matrix which may fit your routing needs. https://vb-audio.com/Matrix/index.htm
DP 11.32 PT 2024.3 VEP 7.x with various VIs
