Hi Mike,
I get part of what you are saying. Yup, I know the green check vs cloud icon. Thankfully I have yet to have issues accessing my individual files or folders with DB, setting aside that I need an active internet connection so travel can present problems. The only time I've ever had an issue was when they changed their filing system about 6 months ago and it all freaked out for a week or so, Luckily I hadn't updated my desktop as they directed, and they resolved their issue. But... it occurs to me that all my fields are sitting there and I have no safety net *if* something were to happen to my files specifically or DB in general. Stuff happens, right (especially these days)?
As I work I swap things so they are on downloaded my desktop and/or laptop and then I either set them to cloud only or allow time to have their default do that. I also share various things with people. So it's a revolving game uploading/downloading files and very handy to have a single copy always available from either computer, while traveling, and being able to send and share with others.
I'm looking for the "idiot proof" (ahem, points at self) way of backing it all up. I followed your advice and bought a basic NAS system when my previous TM ext. HD died. Was a bit of PITA to set up, but it's working seamlessly. I'm not 100% certain if it IS backing up my DB, now that I think about it. I have it set to backup my internal boot drive and not my external sample drives, so I guess it IS including DB? But then only the files that are currently green checked at the time of the backup? I'm also going on what a bunch of people on the DB forum said that "you can't use TM with DB!"
I think for clarity I'd prefer to have 1 place that mirrored DB that didn't involve going to TM backups etc. and looking for things. Easier to get my mind around, to see the exact folder structure etc. and access something quickly. That points me towards buying a 5 TB external and dragging DB onto and letting it work away for a few days. This is why I was asking specifically if a file that is NOT green checked would copy to an external through simply dragging. They would be symlinks etc. then and NOT work. It seems I would have to make sure that every file was downloaded onto my internal hard drive to make sure it properly copied onto an external. I could do that by groups of folders, but it seems a really long, manual process ripe for forgetting something etc. But I guess once it's done then it's about overwriting. That's where the idea of "automating" it via CCC would be helpful.
Someone else mentioned that I should just get rid of DB altogether and put everything on a NAS using it as a server. I guess it does replace it, may own private DB, so to speak, and would be shareable with others, but I wish I had thought of that before buying a Synology DS224+ for TM. It's strictly TM backup. I suppose the investment would pay for itself by discontinuing my DB in a couple of years. Someone else mentioned "using Chronosync, Carbon Copy Cloner, Super Duper or similar to regularly keep what is in Dropbox duplicated to that external drive too."
I *DO* see both the icon in my side bar and tracked it down under library.
Why can't things be simple? I was supposed to be composing and here I am ranting about this instead...
Joel Friedman
