I'm trying to export a specific MIDI track to produce tablature for it in any notation program.
I've used both expore selection as MIDI file; and Save a Copy As... with SMF Type 1.
No matter what I do, the file is empty.
DP 11.33 keeps exporting empty or incomplete MIDI **SOLVED (forehead slap)
Re: DP 11.33 keeps exporting empty or incomplete MIDI
I can't think of anything that isn't obvious. To check, I selected a time range, and tracks with MIDI, went to File>export selection as MIDI, and clicked OK. Right click the exported file and select, Open in Logic, and I get exactly what I exported from DP. Could it be the range selection that's the problem?
Re: DP 11.33 keeps exporting empty or incomplete MIDI **SOLVED (forehead slap)
It's so funny, Bayswater. When I saw you had replied, before I even opened the thread, I imagined your response -- "Were the tracks play-enabled?"
Your first sentence ...
Thanks, as always, for your help. In this case, the answer was inside me the whole time-- (cue: tinkly, mysterious music)
Yup. Obvious. Forehead-slap-emoji.
It does get a bit overwhelming when simple operations require a NAS launch checklist prior to execution. I keep swearing to dig out my Sony SOS 8 track setup.
