DP 11.33 Keeps Crashing (?) when I merge soundbites
I did a remote voice-over recording, and needed to do some edits.
At the remote location DP worked flawlessly. But back at home I'm getting pretty regular incidence of DP going into non-responsive beachball mode (is that a crash or a freeze or a lock up?) At least now I know to save before doing a merge.
But now it's doing it every time.
Re: DP 11.33 Keeps Crashing (?) when I merge soundbites
Bummer. I hate that... when everything works then, one day, it doesn't.
No ideas here other than, if you can, figure out what changed.
Yea, I suspect just having an OWC dock attached, a second display, a time-machine drive attached, and my old RME FF800 (which is a whole $#!+ show of its own)-- is probably to blame.
I started a new project and dragged in all the audio that I need, to start afresh.
I think the next edits I do, I'll disconnect as much as possible, and not use the FF800. Might be time to say goodbye to that.
OTOH, I'm overdue to do a clean install (and purge of unused software). I dread it so much!!
EMRR
Post by EMRR »
If I’m merging and switch to another desktop or app during, DP locks up. Has been true for a few years, 2 different systems.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
EMRR wrote: Sun Feb 09, 2025 7:22 am If I’m merging and switch to another desktop or app during, DP locks up. Has been true for a few years, 2 different systems.
That makes sense. So perhaps because my home rig is running some operations in the background, it creates a similar issue. I suppose I'll have to figure out what to shut off in the background to avoid whatever is breaking it.
EMRR
Post by EMRR »
It was never previously a problem before i jumped to 11 on the Studio from 8 on the iMac.
Doug Williams
Tape Op issue 73
DP 11.34
At this point, I suppose it will be a matter of whether MOTU would look at the crash report, if I don't specifically submit a ticket.
stubbsonic wrote: Sat Feb 08, 2025 7:55 pm Yea, I suspect just having an OWC dock attached, a second display, a time-machine drive attached, and my old RME FF800 (which is a whole $#!+ show of its own)-- is probably to blame.
One never knows. I have the following attached to my Mac:
HDMI TV
Thunderbolt>Display Port Adaptor> Display Port Monitor
TB>Apple TB Adaptor>MOTU 828ES
USBC Powered Hub>Three USB3 Hard Drives
USBC Unpowered Hub>Two USB3/SATA SSDs
Something in excess of Ten USB Devices via several Hubs.
Have you tried re-installing DP?
HC Markus
https://rbohemia.com
HCMarkus wrote: Mon Feb 10, 2025 10:44 am Have you tried re-installing DP?
Seeing how your rig is connected makes me feel like my rig isn't that complicated.
I have another remote session tomorrow, and will be able to put DP to the test again. I'll see how it goes.
If it behaves, I'll assume something in the home studio is contributing and do a little process of elimination.
stubbsonic wrote: Mon Feb 10, 2025 1:12 pm
And I forgot the Two TB-connected NVMe VI Sample drives. Good luck!
EMRR
Post by EMRR »
I did full purge / reinstalls on both systems, no changes with any bugs or crashes.
Doug Williams
Tape Op issue 73
DP 11.34
EMRR wrote: Mon Feb 10, 2025 5:06 pm I did full purge / reinstalls on both systems, no changes with any bugs or crashes.
Sigh. Well, that is a strong possibility here, as well. Still, it is inevitable that I'll need to do it at some point. But it's good that I calibrate my expectations. quiet-resignation-emoji
BTW, I was at the remote session today, and had a crash after merge without other stuff connected, so I guess that tells me it's not related to the other bits & bobs connected.
EMRR
Post by EMRR »
dangit
Doug Williams
Tape Op issue 73
DP 11.34
RayMasse
Post by RayMasse »
On my side keep crashing when I try to open clips window!
