Maag EQ4 MS/Lindell Audio 69 Series not loading, error -10868
Posted: Sat Oct 12, 2024 7:39 pm
by demonsp
Greetings Team! :smash:
I wondered if anyone knows what "error -10868" means.
I'm unable to load the mono version of Lindell Audio 69 Series (AU) with this message appearing:
'Digital Performer has encountered an error.
Mas,1 error reported by Mas Audio Unit Support.
Failure: Initialize 275 -10868 [-10868]"
Maag EQ4 MS wont load at all, crashing the validation test (AU and VST).
I noticed this plugin is data tracking which seems to be a first.
Any clues? (Plugin Alliance plugs)
Cheers;
J.
Re: Maag EQ4 MS/Lindell Audio 69 Series not loading, error -10868
Posted: Sat Oct 12, 2024 8:43 pm
by James Steele
No sure... I'll have to check to see if I have that one, but as a work around, you can often disable the AU and enable the VST3 version instead and it will work in DP.
Posted: Sun Oct 13, 2024 8:29 pm
by demonsp
Thanks Mr. Steele,
I've reported the error to motu.
Cheers!
Posted: Mon Oct 14, 2024 8:48 am
by rp88.2
Wanted to check...
In your signature, if says you are running macOS 10.4 and DP 5 -- is that your current system?
According to PluginAlliance, they are now only officially supporting macOS 12 - macOS 15.
Have you tried the plugins in Logic Pro or another DAW on your current system to see if they are working?
Just wanted to throw that out there.
All the best,
Rich
Posted: Thu Oct 17, 2024 8:05 pm
by demonsp
Thanks for the suggestion rp88.2!
I haven't updated that signature in years.
Running MacOS 10.15 and 10.13/DP 11 without any issues until this plugin, guessing this is the end for any new plugs.
Regards.
Posted: Mon Oct 21, 2024 8:41 pm
by mhschmieder
Hmm, I just bought the Maag EQ MS edition last weekend, but haven't tried loading it in DP yet -- that will have to wait a bit as I'm focused on the non-production side of recording projects at the moment. But as I always do, I run a new plug-in through Vienna Ensemble Pro just to get the authorization out of the way, and the Audio Units plug-in wasn't found so I could only load the VST version.
Posted: Fri Oct 25, 2024 6:19 pm
by demonsp
Interesting..... :unicorn:
DP 11.33 is out, hopefully it fixes this issue.
Thanks for reporting!
Posted: Sat Oct 26, 2024 7:35 pm
by demonsp
Unfortunately DP 11.33 makes no difference with Lindell Audio 69 (mono) not loading.
Can't check Maag EQ4 MS as I uninstalled it from my system.
:banghead:
