How to select multiple audio input sources (Mic and Keyboard) for Windows 11?
Rob Ainscough
Post by Rob Ainscough »
Hardware: MOTU 828 (2024)
Firmware: 1.1.4+D8AF48939D97
Driver: 4.0.9.5601
I've Enable Windows Audio Streams and selected Input and Output:
Windows 11 only allows me to select ONE Line Input:
Digital Performer Bundles Input will only show the ONE "active" input as selected under Windows 11:
So how can I record both vocal and my KORG Pa5X line in audio at the same time in DP?
I know I must be missing something obvious as I'm sure it's common place process.
Cheers, Rob.
Rob Ainscough
Re: How to select multiple audio input sources (Mic and Keyboard) for Windows 11?
UPDATE:
Found it!
DP - Setup - Configure Audio System - Configure Hardware Driver - ASIO - MOTU Gen 5:
Once this is set I see all my inputs:
Is there any way to match up the Bundles Input names to those I've defined via Cue 5?
Cheers, Rob.
