Consolidating a timecode track
Good day to you all. I hope this is the correct section of the forum! Is there any way to create an audio timecode track by consolidating an audio region and “commit” the timecode for that region? Thank you!
Re: Consolidating a timecode track
Not sure exactly what you want to do, but look into Timestamps... DP11 manual page 671
Thank you! What I’m looking for is to create an audio track with the timecode on to send to other departments of the show to do their things with
S
S
SMPTE? You can record the output from the MAS SMPTE-Z plug to an audio track. You can also export the conductor track as a MIDI file for markers and tempo. Not sure if that helps.
DP 11.32 PT 2024.3 VEP 7.x with various VIs
I just discovered that plug-in! Thank you so much!
