Concatenating soundbites in a track?
Hey everyone, I have a concert to mix that is one hour long. I will also master it, and create a DDP for CDs. The multi-track is one contiguous project. The band has broken the ref track into 14 songs that, when played back to back chronologically, would be exactly the length of the project file, with no missing samples between the songs. I will be using this for creating track start timing markers, that the band has predetermined, in addition to having their ref on hand. Is there a way to put the songs into a track, and have them line up exactly one after the other, like "snapping" in Final Cut? It would be very tedious for me to try to sew all the songs together and get them sample accurate with the trackpad. I tried grabbing the 14 (numbered) soundbites and simply dropping them into the track, but I didn't get the result I had hoped for.
Re: Concatenating soundbites in a track?
I think it’s called “throwing”. You use one of the mod key while you drag a soundbite quickly to the left, and it lands up against the previous soundbite. I assume this is sample accurate — otherwise it would be pointless. Maybe in the manual under throwing.
Thanks Bays, that's it! Page 405, “Throwing” soundbites to the next or previous soundbite. You simply use the control key. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
You can also (depending on your version of dp)
Use the “set gap between soundbites”
I think it’s under regions? Not at my comp right now…anyway you select all the soundbites and set gap to 0 and you’re done
