SE single lane data editing and viewing behavior
- pencilina
I think this came up in another thread which I can’t find. Is there any way to view multiple date types/lines (Eg. volume, pan and plugin LP freq) in one SE lane and use the blue check box to set the edit focus (as in previous versions)? And what happened to clicking on the bar at the top of a soundbite to set the lane back to soundbite editing? Maybe the default settings changed or something but I can’t find the settings and I’m getting annoyed with all the extra clicking I have to do. The manual still shows multiple data types in one lane in several illustrations so I would imagine this behaviors is still available. Thanks in advance.
- pencilina
Re: SE single lane data editing and viewing behavior
Crickets....
I guess I should assume theres no way to view multiple data types in a single lane in the sequence window anymore?
I don’t recall ever using that once lanes were introduced so I wouldn’t notice a change.
To see multiple data types in v11.3 appears to require multiple lanes, You can get one type of non note or audio data to show up, but as you say the manual implies you can see multiple types.
No lanes open, just the main track in the SE - If you change the track header to anything other than Soundbites (ie to Volume) in the SE, you're not seeing all the lanes together over the greyed out soundbite? You'll only be able to edit the one you selected, but they should all be there. When displaying the Soundbite that's all you'll see. Also, single click on the soundbite title bar returns to the Soundbite view here. May be something in Preferences, but quick look and I didn't see anything.
DP 11.32 PT 2024.3 VEP 7.x with various VIs
I didn’t find anything in Prefs or setting either. I do recall some screen that showed multiple data types. Maybe it wasn’t the Sequence. Anyway, it would be way to busy for me to want to use.
- pencilina
Hi Charlzs,
That’s correct. Additionally, in any other lave view then soundbites only the lasso is available and I’m unable to switch back to soundbite view clicking on the bar on the top of soundbites.
In the View Menu, have you selected 'Show Only the Active Edit Type'? Uncheck that and/or play with the view filter for edit types. I also learned something I never knew before - If there are automation points for any other type than the one you are viewing in the SE track, you can click on one and it will automatically change the view to that type for editing.
The lasso thing in any other than soundbites is all I've seen. If you get right on the automation line/data it should turn into a hand. Pencil should work too.
I noticed that if you have a lane open for a data type, that one doesn’t show up superimposed on the Soundbyte view of the track. If you have lanes for all the data types, none of them show up. If you close all the lanes, they all show up on the Soundbyte view. (As long as the View option mentioned above is properly set).
So you can close all the data lanes and edit everything in the main track view, or use the lanes, but not both. Is this new? I don’t remember it being like this in earlier versions.
- pencilina
That was the ticket! Thanks my man.
