Izotope RX9 worked under 10.13.6 though not officially supported.
RX10 installs on my iMac under 10.13.6, but crashes without opening. All of the RX10 AU plugs except music rebalance load and run under DP8.
Like I said, trivia!
RX10 trivia, DP8, 10.13.6
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
Re: RX10 trivia, DP8, 10.13.6
The stand alone app, I presume? I would try starting it in Safe mode by holding the Shift key. This rebuilds any paths. If successful, quit the app and restart normally. It'd surprise me if this works but it can't hurt.RX10 installs on my iMac under 10.13.6, but crashes without opening
Found this but I'm betting you know it already:
I notice that RX10 did not overwrite RX9 on my Mac. Yours, too?Notes
All plug-in formats are 64-bit only.
RX 10 plug-ins are not available in VST2 format.
Spectral Editor & Music Rebalance ARA plug-ins are available in Logic Pro on Intel or Apple silicon Macs (in Rosetta only).
Ambience Match, Dialogue Isolate and De-rustle plug-ins are AAX Audiosuite for Pro Tools only.
Repair Assistant plug-in available as Audiosuite only in Pro Tools and VST3 & AU formats in other DAWs.
Yes, standalone. Actually every update has installed as an additional version for me. With the plug ins it’s actually a growing problem, I’ve got rx5 through rx10 plugs in DP since it depends on when a session started or was last opened as to which version is active. Seems like they’d find a way to update and carry settings forward.
I’ll try safe mode.
I’ll try safe mode.
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
