Orchestral Collection
BERLY
Post by BERLY »
Hi,
I've an old Prosonus Orchestral Collection that I love very much.
Unfortunately, it seems that M5 doesn't read the .iso files anymore.
Is there a tip to convert the .iso file into something that M5 would recognize?
Thanks, best regards
Christophe, studio-slc.com
Christophe Berly
http://www.studio-slc.com
France
Re: Orchestral Collection
>Unfortunately, it seems that M5 doesn't read the .iso files anymore.<
Did it ever? .iso isn't in the supported list for MachFive3
https://motu.com/products/software/machfive/specs.html
.iso files are normally disk images that are backups of optical media. Your libraries should be in the file, not the file itself.
https://www.howtogeek.com/230468/how-to ... and-linux/
Normally, one double-clicks on an .iso file to mount it. Once mounted, you should see your libraries and can drag them to a folder. Now, if they are supported by MV3, you should be able to point its browser to them and they should load—assuming that they're a supported file type.
If that doesn't work, the file extension may be wrong. If so, you need to know the correct extension. Both Mac and Windows can batch-convert file extensions in the OS if that's what is needed.
If the actual files are a type you don't recognize, perhaps someone here will.
BERLY
Post by BERLY »
Yes it did work.
Mojave don't open nor mount it.
But it works again now. I've simply opened it in M5 standalone, and then I was able to open it again inside DP.
I don't understand why, but so far, it works.
Best regards,
Christophe
Christophe Berly
France
