Help getting new Faderport to work with DP11 [RESOLVED]
- daveyboy
Apologizes if this is the wrong forum. I've been trying to get what control surfaces I own to work with DP 11 and have added a Faderport 2 to try out. The only big thing I can't figure out (and maybe it's impossible) is for it to change tracks. Right now it seems to be "stuck" on the first one in the channel list. I can't manually scroll to other tracks and have tried every MCU/MCU compatible combination I can think of. Anyone getting this work well in DP 11 (or even DP 10 for that matter)?
Dave
www.dbwproductions.com
Re: Help getting new Faderport to work with DP11
Have you switched the Faderport operating mode to either MCU or HUI? It's kinda buried in the manual, but my FP2 came with an extra sheet of paper that showed how: hold down the "Next" key while powering up, wait for buttons to start flashing, then pick a mode.
Mute = MCU Logic
Arm = MCU Ableton
Bypass = MCU Cubase
Touch = HUI ProTools
I haven't tested every function, but with DP10 on my system, MCU or HUI allow changing channel focus with the Prev/Next buttons.
HTH
Mute = MCU Logic
Arm = MCU Ableton
Bypass = MCU Cubase
HTH
Mac Studio Max | 32GB | 14.5 | 828es | M4 | DP 10.13 | Studio One 6.6 | Logic 11
- daveyboy
Yes, I'm switching all those and trying them out. I couldn't get either dp10 or 11 to work in any mode but will keep trying.tremo wrote: ↑Sun Aug 01, 2021 12:07 pm Have you switched the Faderport operating mode to either MCU or HUI? It's kinda buried in the manual, but my FP2 came with an extra sheet of paper that showed how: hold down the "Next" key while powering up, wait for buttons to start flashing, then pick a mode.
Mute = MCU Logic
Arm = MCU Ableton
Bypass = MCU Cubase
HTH
Dave
Huh. And you're able to select Presonus FP-2 in Setup/Control Surface Setup?
- daveyboy
I’ve gotten the FP2 to work in DP11 except for the issue that it doesn’t follow track selection. So, it’s super tedious selecting the track you want to adjust. Is there a setting in DP I don’t know about that gives me this ability (Logic has a pref for this)? The Faderport, which works great in DP10, follows selection like a champ.
Dave
- pneron
Hi Dave
I just got a FaderPort 16 and can only work 8 chs at a time...I assume this a driver limitation in HUI mode?
DP11, Genelec 8341, MacStudio, Quantum, 2x Faderport16.
LegacyDAW: Amiga2000 3xAD516 SunRize cards
With a one channel controller, you need to scroll to the bank, then scroll to the track. I won't just follow the selected track. At least that's the way it worked for me. I got rid of my X-Touch One for an X-Touch Universal and X-Touch expander. It works so much better.
With a 16 channel controller, you probably need to set up two devices, a main and an expander.
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 15" Mid-2019 MBP 2.4 GHz 8-core i9, 32GB RAM, Ventura 13.6.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2; USB 2.0: Ext USB3 drives, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; USB 3.0: Stream Deck XL, M Audio Oxygen 49, Akai MPD218, Console One Mk3, SSL UC1, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.31
aka Dave Williams
* DP 11.31
My Faderport (the current model) has worked flawlessly with DP11. Check out the setup videos at https://motu.com/en-us/products/software/dp/videos/. After I set it up, it just worked.
This worked for me:
I set my Faderport 16 to Logic
IN DP control surface
Driver Mackie Control
Unit Mackie Control input PresonusFP16-1 output PresonusFP16
add second unit
Expander XT input MIDIIN2(PresonusFP16) output MIDIIN2(PresonusFP16)
Took a while to figure this out trial and error, but seems to work fine
Let me know if works for you
This on Windows 10
add second unit
This on Windows 10
- pneron
Thank you...I will give this a try
- pneron
That worked CopyRon ! I am actually using MacStudio machine. This was helpful....at some point I should probably get another FaderPort16 to bump up to 32 tracks.
Thank you
Thank you
Glad it worked!
- pneron
Thank you !
- pneron
Re: Help getting new Faderport to work with DP11 [RESOLVED]
Update: I just got another FaderPort 16 and was able to configure 32 Tracks ~
- Screenshot 2023-06-09 at 8.25.13 PM.png (26.57 KiB) Viewed 1925 times
