Model 12 Question
GoodBeat101
Model 12 Question
Post by GoodBeat101 »
I wanted to know if the drum sounds from each cell in Model 12 can be routed to their own audio track? When you select the drop down menu for each cell in Model 12 the only options are Main Outs and Aux 1-6. Any ideas?
Phil O
Re: Model 12 Question
Post by Phil O »
You can use the aux outs in Model12 as outputs. You will just need an aux or audio track to send it to. So, for example, set your cowbell's output to Aux1 and create an aux track with input set to Model 12-Aux 1 LR and output set appropriately. Alternatively, if you wish to record that track you can use an audio track with input set to Model 12-Aux 1 LR. As far as I know there's no way to directly set individual instruments to bundle outputs from within Model12.
Phil
DP 11.32, 2020 M1 Mac Mini [9,1] (16 Gig RAM), Mac Pro 3GHz 8 core [6,1] (16 Gig RAM), OS 14.5/11.6.2, Lynx Aurora (n) 8tb, MOTU 8pre-es, MOTU M6, MOTU 828, Apogee Rosetta 800, UAD-2 Satellite, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
