Bounce To Disk
Posted: Wed Feb 02, 2005 4:32 am
Hi ,
I have recording my music at 48KHz & 24 Bit in DP 4.52. Then I bounced all the tracks to Disk prepare for CD burning. I exported the tracks to AIFF , then a CORE AUDIO EXPORT OPTIONS appeared, that let me choose bit dept to 16 bit, sample rate to 44100, but there I don't know what's the difference of the SR Convert Quality at Maximum, High, Medium, Low or Minimum. I checked the big manual but couldn't find explanation about it. Please explain.
What the music I do is very unconventional, which is having extreme bass and high frequency ( up to over 15 KHz) sound & spikes. I found that after I burned it to an audio CD, the sound changed a lot. Especially when I play it by my cheap 1 bit ADC Discman, the high frequency spike sound weird. Is this something about my Discman player, or I shouldn't record the music tracks at 24 bit & 48KHz at the beginning? Will I re-record everything in 16 Bit 44.1 KHz better?
Your earliest reply is highly appreciated.
Thank you
Simon Ho
simonchho@netvigator.com
Thank you
Simon Ho
