unwanted progrem changes
Discussion of all things related to MOTU's powerful MX4 software synthesizer.
Jim
Post by Jim »
Hi. I just upgraded to DP9 with MX4 and have a newbie question.
Whenever I hit play in DP, my MX4 reverts back to Bank 1, Patch 1, even if I have no CCs or other events (other than notes) in my track whatsoever.
I can't find a place to have it stop doing this. Help!
I meant "program" not "progrem."
Thank you,
Jim
Re: unwanted progrem changes
The only other place I can think of to look is in the TO (tracks overview) in the columns "Patch" and "Default Patch".
Jim
Post by Jim »
That is a good guess, but that wasn't it. Thanks for taking the time to reply! I appreciate it.
I've edited my earlier reply:
I thought I'd worked around it by creating a new track and pasting the "old" events into it.
But, I started working on another older Project started in an earlier version of DP, and put MX4 on a track, hit play, and MX4 changed patches on its own while playing several times. And again, this is without any Program Change events in the Track.
Jim
daniel.sneed
Post by daniel.sneed »
Just guessing. For troubleshooting, my 1st test would be disabling program change in view filter window.
Falcon, Kontakt, Ozone, RX, Unisum, Michelangelo, Sparkverb, Soundtoys
Thank you,
Jim
You can go to the initial post (if it’s yours) and select EDIT. Then correct/change the title.
