UVIx Modulation Switching
haiknal
Post by haiknal »
Anybody Out there have any luck with Creating Program Switching using Modulation? It is an option in UVIX to merge 2 programs using a performance parameter like modulatiomn to switch between the 2, but it comes into MAch five as 2 seperate programs. Is there a way to do this directly in Mach 5?
dacart
Re: UVIx Modulation Switching
Post by dacart »
Presumably you should be able to do this in Expert mode and doesn't seem that hard to set up (see the manual for details) the problem I'm having is getting it to work!
"Ted, you know the way you are? Don't be that way!" Lou Grant to Ted Baxter
