loading a Kontakt .nki file into M53
Hi,
When I try to load a Kontakt 4 program I get the error message "Couldn't load program". Is there a special trick to load a Kontakt .nki program?
I tried to open it just like an Machfive program. Maybe there is another way to do it? I can't find anything about it in the manual, it just says M53 can load .nki files.
cheers,
Anton
cheers,
Anton
PC i3 8GB RAM / Windows 10 64bit
Studio One 3 / MOTU MachFive 3 / Steinberg UR28M
Re: loading a Kontakt .nki file into M53
Nobody uses a Kontakt library in MachFive? It should be possible, right?
Not necessarily. All Ktk programs are not M5 compatible.
Thanks for the reply. Is there nothing from Kontakt that can be loaded into M53? I thought M53 could load Kontakt 1-4 files?
cheers,
Anton
cheers,
Anton
It's hit and miss. M5 has a bigger CPU hit so I'd stay with the Kontakt player. Large and heavily scripted instruments should have their own players. This allows DP to use multi-threading and spread the load across cores. This is true of any VI players in DP - assuming you have a multi-core machine and Snow Leopard or better.
So to load a Kontakt .nki file is the same procedure as loading a M53 file? It's just trial and error if the Kontakt file will load?
cheers,
Anton
cheers,
Anton
That's been my experience.
Up to Kontakt v4.1.ahoutriet wrote:Thanks for the reply. Is there nothing from Kontakt that can be loaded into M53? I thought M53 could load Kontakt 1-4 files?
cheers,
Anton
(In my case, v4.10.3681)
2017 2.9 GHz MPB/1TB ssd; loaded 2012 i7 quadcore Mini, OS 10.15.5
DP 10.11, Logic 10.5.1, Silverface Apollo Quad/TB, K12UC, Falcon, Integra 7, MIDI guitars etc.
- UltimateOutsider
If the Kontakt patch includes separate WAV files, try placing a copy of the NKI file into the same folder as the WAVs and import the NKI from there.
