Plugin display refresh rate?
etl17
Post by etl17 »
It seems that a lot of my plugins have a "choppy" update of their display (for example UAD plugins). Some others (for example iZotope plugins) are fine. Is there any way to force a more frequent / higher priority display update for problematic plugins?
DP 9, Win 7 64bit, 24GB RAM, RME HDSPe / Digiface, UAD 2, Powercore x8, HUI, 1 million plugins!
davidthriller
Re: Plugin display refresh rate?
Post by davidthriller »
Try this plugin: http://www.team-mediaportal.com/files/D ... ateControl
This is one of the best plugins that can Refresh your rate, and best of all, you can control it.
etl17
Post by etl17 »
The link doesn't seem to point to a valid file?
Zee123
Post by Zee123 »
Get pass4sure demos for test king and wikipedia with 100% success guaranteed. Our high quality University of Cambridge prepares you well before appearing
etl17
Post by etl17 »
Bump!
kelldammit
Post by kelldammit »
i'm curious what's behind this, as some do work fine, and others do not.
Feed the children! Preferably to starving wild animals.
ASUS 2.5ghz i7 laptop, 32Gb RAM, win10 x64, RME Babyface, Akai MPK-61, Some Plugins, Guitars and Stuff, Lava Lamps.
This appears to happen with some VST plugins on both Mac and PC. E.g. a couple of the PSP Stereo plugins have a sluggish refresh. VST is new to DP, so no doubt there are some things to fix. Identifying specific plugins with this problem at MOTU Techlinks would be good.
etl17 wrote:It seems that a lot of my plugins have a "choppy" update of their display (for example UAD plugins). Some others (for example iZotope plugins) are fine. Is there any way to force a more frequent / higher priority display update for problematic plugins?
Hmmm.... Isotope's RX 2 would not have prompted that remark -- it is a real resource hog with the GUI open. They did get a whole lot better with RX 3.
This leads me to believe that the plugin designer has more to do with the performance than DP.
kelldammit
An update. I've had this issue in a big way with EQuilibrium and COMPassion. I reported via MOTU techlink, and they've replicated/confirmed as a bug...and passed along to dev.
Hopefully we'll see some sort of fix at some point.
Cheers,
Kell
etl17
Post by etl17 »
Anyone is aware if this is being addressed by the upcoming release 9?
Since the problem hasn't been DP or MOTU plugins, I wouldn't hold my breath.
