Hi,
I'm using my 828mkII with Win2K Pro and Sonar4PE. Everything works fine. When I come to use it with Windows media player or Goldwave then I get sporadic clicks on playback. I've checked Win2K Audio settings and all looks fine but on looking at the Hardware Device Manager I see that there are other drivers still there like the AC97 codecs and legacy audio stuff. The 828 is the only device on my PC and I have a Keyspan PCI 1394 with TI chipset so I'm not sure if the other drivers are necessary as I don't have a second sound card.
I've searched the posts to see if any one else has had this problem and where the area of fault could be. It's puzzling to me that with Sonar driving the unit then everything works as it should.
Any pointers would be appreciated
Kind regards
Phillip
828mkII - Clicks with Win2K Pro but not with Sonar
Always tell the truth - the truth will set you free
Re: 828mkII - Clicks with Win2K Pro but not with Sonar
Are you using Asio or wdm with Sonar?
It also doesn't suprise me you get this from some native windows apps. Would you expect more?
It might be something as simple as a hardware acceleration setting.
Try shutting down your ac97 device in Bios too. It should disappear from device manager after that.
