Choose New Take for many tracks at once
apanacci
Post by apanacci »
Hey guys can anyone help. When I recording on say 10 tracks and I want to record a 2nd take on all. How do I choose take 2 for all? I grouped all the tracks but I had to go thru each one and choose take 2. Thanks
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
1nput0utput
Re: Choose New Take for many tracks at once
Post by 1nput0utput »
By default, the keyboard shortcut ctrl-opt-n creates a new take in all record-enabled tracks.
FMiguelez
Post by FMiguelez »
Select your tracks. Press "t" and keep it down while you select New Take from any selected track. Bam!
Or, you can group your tracks normally, but you need to make sure you have set the things that you want your group to respond to (takes, in this case).
Remember you can have lots of groups with lots of different properties (things they will do as a group). Maybe you just want a group of tracks for selection, or only for showing, or maybe you want it to respond to everything.
Tim
Post by Tim »
Yeah... hold 'T'... and make sure that the Take stuff is enabled in Temporary Group Type (Group window/mini menu).
wurliuchi
Post by wurliuchi »
1nput0utput wrote:By default, the keyboard shortcut ctrl-opt-n creates a new take in all record-enabled tracks.
Now that's cool! I had no idea. I've always done the group thing. Why don't I know these things!!!
DP 6.03 • MacPro 2x3 Ghz Dual-Core Intel Xeon • 9 GB RAM • 10.5.7 • Prayers
motuscott
Post by motuscott »
Good one!
imac 2.4 Core2Duo 4G RAM, MBP 2.26 Core2Duo 8G RAM/ OS 10.6.8
MOTU 828mk2, microlite
DP7.24, Reason6.5.3, B4II, Ethno, RMX
