bus multiple tracks at the same time?
Is there a way to assign multiple track sends at the same time in the mixer rather than clicking each channel send and running down the list of output options? Just seems to waste time. Thanks.
Re: bus multiple tracks at the same time?
No. Not that I know of.
DP 6.03 • MacPro 2x3 Ghz Dual-Core Intel Xeon • 9 GB RAM • 10.5.7 • Prayers
This has been discussed before here; all seemed to agree that a method for multiple-track configuration is sorely needed.
It is my hope that such a method would feature the ability to predefine the send levels too.
yes please!
often easier to make new channels with correct bus/aux arrangements if you got lots to do.,... make a bunch and copy and paste stuff in...
motu mind meld...
motu mind meld...
macpro 3 gig - 5 Gig RAM 10.6.3 Motu 2408 mk 2 Mackie HUI DP 7.21 intel imac 3 gig ram traveller OS 10.6.3
http://www.fork-media.com
At the very least you could re-arrange your bundles temporarily so the item you are assigning to appears in a more convenient place on the menu.
- Eleventh Hour Sound
As a workaround:
If it's a track setup you often use, you could have a templete with everything ready to go. Also, if you're adding tracking on the fly you could use the duplicate track option to create tracks with the same track output, sends, and even plug ins.
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars
I like that: Template + Complete.RecordingArts wrote: templete
In Pro Tools LE, you can assign multiple tracks to an aux send by holding down a modifier key - I think it's 'option' - while selecting a send. I think it applies to ALL mixer channels (rather than, say, all visible channels), though I'm not sure. This isn't ideal, but it's better than DP, particularly for assigning tracks to main reverb or to a headphone mix while overdubbing.
Anybody who wants something similar in DP, PLEASE send submit a request to MOTU via their online feedback form. I've been asking for this for at least a couple of years.
I wish it could also be done in the Audio Assignments window, which applies to selected tracks.
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 14.5
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 14.4 via Open Core Legacy Patcher
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
Is this still the case? I.E., no way to assign multiple channels to the same buss at once. If that's the case... then is there also no way to assign the same plugin to a group of tracks at once?? I know I do this ALL the time. I'll assign the same plugin EQ to all my drum tracks, or the same compressor to all my rythem guitar tracks, etc.
I know this thread is a bit old.. but in response to the post above..., when in PT:
1) Holding "option" will do whatever you want to all tracks.. whether that's assigning a send, an output, a plugin, etc.
2) Holding "shift - option" will only apply to selected tracks...
3) "shift - option - command" will apply to all selected tracks in consecutive order when applying things like inputs, outputs etc. I.E., select all drum tracks, hold "shift - option - command" and assign your first channel to input 1, now your second channel will be input 2, third input 3, and so on...
I actually came upon this thread while searching for an answer to a different question though. Is there a way to rearrange several tracks at once in the 'tracks overview window'? I.E., can I select all my string tracks and drag them to the top of the page, or do I have to do it one by one?
At the studio: 2" Sony/MCI 24 Track, 36x24 Neotek IIIC, Modest rack and mic selection, PTLE 7.4, 002R, Apogee AD8000, PPC Mac 2.7Ghz + 4GB Ram, OSX 10.4.9
Check out my completely out of date studio website: http://www.mysteriousredx.com" onclick="window.open(this.href);return false;
At Home: Intel iMac dual 3.06Ghz + 4GB Ram, OSX 10.6.2, DP7.12, Logic 9.1.1, Numerology 2.3
- Dan Worley
benmrx wrote:I actually came upon this thread while searching for an answer to a different question though. Is there a way to rearrange several tracks at once in the 'tracks overview window'? I.E., can I select all my string tracks and drag them to the top of the page, or do I have to do it one by one?
These are the default Commands:
Control Home - moves selected tracks to the top
Control End - moves them to the bottom
Control Page Up - moves them up by one track
Control Page Down - moves them down by one track
c-ya,
Dan Worley
DP10.13
Ahhhh... I'm actually working on a small keyboard at home, so I don't have the "home, end, page up, page down" buttons, but I'm sure I can customize these commands. Thankyou sir....
Any idea regarding bussing or plugins on multiple tracks simultaniously?
The Audio Assignments window (option-A) acts on selected tracks and can route them to the same outputs, consecutive outputs, or to aux buses. The key commands you mentioned would be great to have too - please submit a feature request to the MOTU suggestion box (I've been asking for this for a few years now, after seeing it in PTLE).benmrx wrote:Any idea regarding bussing or plugins on multiple tracks simultaniously?
EDIT: Corrected this post to reflect that Aux buses ARE included in the Audio Assignments window.
Bob
DP 11.23
DP 11.23
I route multiple tracks to aux buses that way all the time.BobK wrote:
The Audio Assignments window (option-A) acts on selected tracks and can route them to the same outputs or consecutive outputs - but only to hardware outs, not Aux buses.
Tim wrote:I route multiple tracks to aux buses that way all the time.
You're right. Not sure what I was thinking. Will go back and correct my earlier post.
Thanks Tim!
Bob
DP 11.23
DP 11.23
- Dan Worley
I think he means he'd like to see something for routing Sends on selected tracks like the way Audio Assignments works for assigning I/Os.
c-ya,
Dan Worley
c-ya,
Dan Worley
DP10.13
