Big problems with 4.6
I cannot open my projects. I get shutdown of DP and a -39 error
Machine Model: Power Mac G5
CPU Type: PowerPC G5 (2.2)
Number Of CPUs: 2
CPU Speed: 1.8 GHz
L2 Cache (per CPU): 512 KB
Memory: 1.25 GB
Bus Speed: 900 MHz
OSX 10.3.7
MIDI Timepiece AV
MOTU 896HD
Glyph FIrewire Drive for audio
Number Of CPUs: 2
CPU Speed: 1.8 GHz
Memory: 1.25 GB
Bus Speed: 900 MHz
OSX 10.3.7
MIDI Timepiece AV
MOTU 896HD
Re: Big problems with 4.6
After installing 4.6 - did you repair permissions?
Also - try installing 10.3.9 and then reinstalling DP 4.6.
DP 4.52/ DP 4.6/ OSX 10.3.9/ G5 Dual 2.0/ 1.5 GB RAM/ Reason 3.0/ VSTs (PSP, TC Native), MAS (DP Plugs), AU (PSP, Ohmboyz)/ UAD-1 (3.9)/ MOTU 828 (2)
thanks, will try that....
well...upgraded OSX to 10.3.9, repaired permissions, reinstalled DP 4.6, repaired permissions again -
4.6 either:
crashes when trying to open any project
or fails to open file and shows error -39
4.6 either:
Did you delete DP 4.5.2.?
The 4.6 upgrade won't do it for you.
It happened to me once but after delete the old one, no problem.
- bralston
Error -39 is a file system error of some sort. There could be errors in the file tree of OSX. Do you have disk warrior? I would recommend it, boot off of its CD and have it fix the OSX file system and catalogue tree. Make sure all firewire devices are unplugged from the computer when you do this too. Make sure you have backups of audio and other important data before you do this.
That is my guess...but there is most likely some other underlying OSX issue that is causing this problem. DP4.6 should be fine on that system. I have it running on my dual 1.3GHz G4 under 10.3.9 just fine.
<small>[ July 11, 2005, 10:27 PM: Message edited by: Brian W. Ralston ]</small>
Regards,
Brian Ralston
Brian Ralston
deleting 4.52 won't change the behavior of 4.6.
tested 4.6 on a client session today and switched back after 3 crashes. waiting on 4.61 at this point.
Dual G5 1.8, 10.4.8, 3GB RAM, SSL X-Logic 24 channel ADDA feeding RME card., MIDI Xpress, Liquid Mix, analog summing (Studer 902).
If memory serves, -39 means "unexpected end of file" which means the file you're trying to open is corrupt.
- Can you open it in an older version of DP 4?
- Do all your DP files produce the same error?!
Just for you guys !!!!
I still use 4.6 and 4.5 independently with the same project ....
So , it must be a file problem ....
Aramis
Aramis
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
I've gone back to 4.52 and it works fine
I tried opening a new file in 4.6 and then using the Load function
but that doesn't work either
I don't have Disk Warrior, but I do have TechTool and have run file tests and it shows no problem.
I doesn't matter what DP file I try to open with 4.6 - it won't open any of them.
- Henry Robinett
Try saving a version in 4.52 and remove the plug-ins. See if that opens without any plug-ins. If it does then you have to put them back in one by one to see which plug is corrupted or incompatible.
Sometimes I've had a DP file get corrupted. The worst case was I had to open a new file and import the soundbites. But you can also load the board and TO too.
All the best,
Henry Robinett
2019 Mac Pro 16 core, 192 GB; 2 MacPro 5,1 Metric Halo ULN-8 3d (x6), ULN-2-3d, MIDI Express XT,
DP10.13, UAD2 Quad TB,Duo,solo, Fractal Ax Fx III, FM3, LF+12+, Altiverb 7, Pianoteq7, Falcon, Keyscape, Omnisphere, Kontakt 5, Superior Drummer 3, Slate Drums, Live 10, Battery4, Diva, Spitfire Chamber and Symphony Strings, Ivory 2, Spectrafoo, Millennia HV3-D, many mics, many guitars . . ..
Henry Robinett
Originally i had the same error.Originally posted by belexes:
Number Of CPUs: 2
CPU Speed: 1.8 GHz
Memory: 1.25 GB
Bus Speed: 900 MHz
OSX 10.3.7
MIDI Timepiece AV
MOTU 896HD
After my insatll of 4.6 i had to open my files after opening DP until i set the file preference to 4.6 from 4.52.
Fibes
"You can like it, or not like it."
DP 7.24, 12 Core 2.66, Reason, Live, UAD-2 full meal deal, Sonalksis 315 & 517, DUY Everpack, Altiverb 6, Apptrigga, Autotune 5, OHM Force Experience, Audio Damage Dishord/Adverb/Dubstation, PSP full meal deal, Camelphat/Space, Wave Arts Power pack and many more.
Try this:
- First, backup your Audio Files folder.
- Then archive it (control-click it in the Finder, choose Create Archive).
- Drag your Audio Files folder to the Trash, and empty the Trash.
This is so that DP cannot find the audio files anywhere. Alternately, if you have a second drive avaialble (HFS+ formatted), you can simply copy your Audio Files folder to that drive instead of archiving.
Now open that DP project. It will (obviously) tell you it cannot find the audio files; just press OK. If the file opens OK, it looks like a corrupt sound file. Try adding the soundfiles back one at a time and see when the issue resurfaces.
MOTU Tech Support
http://www.motu.com/techsupport
I have tried ALL of the fixes listed in this form - including some which are not
1. trying to open from a different user
2. Deep cache clean (Tiger cache cleaner)
3. permissions and bindings rebuild (using TCC)
4. MIDI only (audio disabled)
5. Save a copy as...
6. All third party plugins removed
7 finally - a clean install of OSX 10.3.9, reinstall DP and try all of the above again
The problem persists
