NEW STICKY FOR DRIVER DOWNLOADS!!
resolectric
Re: NEW STICKY FOR DRIVER DOWNLOADS!!
Post by resolectric »
bvalentin wrote:please help me, i lost my MOTU 2048 MK II cd drivers, where i can download them? thanks.
MOTU's website.
Paulo Miranda - AMPstudio
Silence is the new loud.
radar23
Post by radar23 »
Hi,
Could someone please post the 64Bit Vista drivers for the MTP AV Parallel that where available from MOTU in late 2009.
Thanks, as there are many user who wish to use their old parallel MIDI MTP AV's with windows 64bit OS's.
Cheers
Radar
1nput0utput
Post by 1nput0utput »
radar23 wrote:Hi,
Cheers
Radar
If I recall correctly, the older parallel MTP-AV was never compatible with 64-bit Windows.
Ganapoes
Post by Ganapoes »
OK... well does anyone have any idea why my drivers installer app crashed? And how I can manually uninstall the messed up drivers?
resolectric
Is the system accepting a reinstall over the corrupt installation?
If so, do a full install (it should replace the corrupt files) and then, if you wish, do a proper uninstall.
After, reinstall again, a "clean" install. Hopefully without crashing.
If the system doesn't allow you to reinstall on top of the corrupt installation you should go to the registry and delete "Mark Of The Unicorn" and "MOTU" entries from both HKEY_CURRENT_USER and HKEY_LOCAL_MACHINE registry sections.
Also, look for MOTU folders in Program Files and delete them.
Then, do a clean driver install.
And return to the Forum to let us know about the forthcome of your situation.
Thankyou.
califband777
Post by califband777 »
I just bought an 828 mkII, downloaded install zips from MOTU using 3 different computers, none of these zips will extract, any help is appreciated.
califband777
MOTU support phone number is always buzy, been trying for hours ARGGG, zip file wil not extract on a mac machine nor 3 different window machines, can't get MOTU to respond., was not able to access the files posted @ amazon, Very frustrating - any sugestions?
Steve Fogal
Post by Steve Fogal »
For the Motu Timepiece MTV AV parallel, these seem to be the page where the XP drivers are located for the Timepiece (lower on the page - the WDM drivers).
http://www.motu.com/download/download_m ... duct_id=16
As I think I understand, the USB & parallel versions may use the same drivers...? They do seem to also be for other Motu MIDI units as well.
[PS, for reference, was told by Motu, the USB version's manual also cover the parallel version.]
The drivers on the above link worked for my Motu MIDI parallel MTP AV Timepiece.
Garry
Post by Garry »
Hi all,
new to the forum here so I apologise if this has been asked already...
does anyone know if there are going to be any windows 10 drivers for the motu 828 mk2?
just installed windows 10 and the dear old motu is the only device not working
k_trout
Post by k_trout »
Garry wrote:Hi all,
sorry i cant help but
thanks for the heads up man
been putting off installing win 10 till i hear if motu drivers support it
though check this post(last post) from last year
http://www.motunation.com/forum/viewtop ... 14&t=58543
There certainly will be drivers for it. MOTU supports all its gear across both major OS brands.
It'll just be a matter of time, but shouldn't be too long, especially if W10 is embraced in numbers by audio folks.
jammer
Post by jammer »
I've just hit this brick wall as well.
Upgraded to Windows 10 and the only device not working is my Traveler.
Strangely the CueMix app works and I can even see the audio level meters responding as per the hardware meters but Windows 10 cannot see the device.
Odd ...
Seriously, based on MOTU's past performance, I'd say you won't have to wait long.
jammer
Post by jammer »
Sure, that's why I incorrectly assumed they would already have support.
Garry
Post by Garry »
thanks for the quick replies gents..... ive had to roll back to windows 7 for now (urgent recording needed) and the roll back was very very easy .... but will reinstall Windows 10 as soon as the drivers appear
Thanks again
