DP 11.32: Anybody else notice the track selector is broken in the Mixing Board view--?
Re: DP 11.32: Anybody else notice the track selector is broken in the Mixing Board view--? (not broken)
Perhaps the original subject could be changed to from "broken" to "harder to find/click".
stubbsonic wrote: Sun Jul 14, 2024 6:29 am Perhaps the original subject could be changed to from "broken" to "harder to find/click".
Maybe some with the problem could try a different theme and see if that fixes things, and let us know. A lot of things became difficult to click over time as resolutions increased, but this wasn’t one of them for me.
jeffcloud
Post by jeffcloud »
Yep, I just experienced the same issue spending 10 minutes trying to figure out why I can't get a track to show in the mixing board in order to adjust its level. Drove me batty. Things happen with software and coding, but this is something that needs to be fixed immediately. ⚡️ LOVE DP and have been using it since it was just "Performer" before digital audio. Does anyone know if the techs at DP read these issues?, as it says this forum isn't affiliated with MOTU?
EMRR
Post by EMRR »
There does seem to be a graphics freeze after sitting inactive a prolonged time, blacked areas and things missing. Changing tabs and returning clears it. Just did a full uninstall/ reinstall, no change.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
jeffcloud wrote: Fri Oct 11, 2024 2:12 am Yep, I just experienced the same issue spending 10 minutes trying to figure out why I can't get a track to show in the mixing board in order to adjust its level. Drove me batty. Things happen with software and coding, but this is something that needs to be fixed immediately. ⚡️ LOVE DP and have been using it since it was just "Performer" before digital audio. Does anyone know if the techs at DP read these issues?, as it says this forum isn't affiliated with MOTU?
I would not rely on MOTU to see your post. Go to MOTU.com and submit a tech link. I submitted two graphic bug reports via tech Link prior to 11.32's release; both were fixed in that release.
Also, you might take a minute to set up a signature with critical system stats; this helps those who want to help you here understand what you work with. :smash:
HC Markus
https://rbohemia.com
Post by Rick Cornish »
bayswater wrote: Thu Jul 11, 2024 7:40 am
greg328 wrote: Thu Jul 11, 2024 3:47 am Is there a way to share that Beyond Black theme here? I’d like to try it-
Greg
Should be searchable here at motunation. That’s where I got it. Rick Cornish did it. Using the Google search you can find V2.3. If RIck sees this he might tell us where V2.4 is.
Here you go, gents: Beyond Black v2,4
And, FWIW, I'm not seeing the issue with the track selector the OP mentioned on my screen.
Screenshot 2024-10-11 at 3.21.03 PM.png (54.19 KiB) Viewed 2476 times
(As always: I thank Monkey Man for the moniker. 👍🏻)
James—Could this be made into a sticky? Seems like one of these requests comes up every 6 months, or so. (64 downloads as of today)
Rick Cornish wrote:James—Could this be made into a sticky? Seems like one of these requests comes up every 6 months, or so. (64 downloads as of today)
Do you mean the original BeyondBlack thread? Sure. I need to do that when I get home. Not sure I can right now via mobile.
James…..
No rush. Just a thought. Even just posting the download link would be fine.
Rick Cornish wrote: Fri Oct 11, 2024 5:09 pm James…..
I made THIS topic a sticky: viewtopic.php?t=72317
Do you think maybe you could periodically update the 1st post with the latest link and also edit the subject header with the newest version number? That thread still says it's 2.3. Thanks!
P.S. I do have the ability to add a "Downloads" page to the Quick Links. menu at the upper left, so I may do that in the future. It would be good to have that and CherryPicker3 there. I'll probably have to add a little blurb about each download... especially since Cherry Picker "breaks" with Mojave I think. Also I don't mind hosting your theme here, but you may have reasons you'd prefer to keep it at WeTransfer which is fine. I could add that link to the "Downloads" page when I decide to do it. As of now, your theme and Cherry Picker would probably be the only downloads for now.
Michael Canavan
Post by Michael Canavan »
Just an FYI because it always confused me for decades.. [Command Shift t ]calls up the Universal Track Selector, this one updates to whatever window is in focus. and in the Consolidated window opens on the right. [Option Command e] opens the Individual Track Selector, this one opens on the left of the window and only shows that windows track selection. Awkwardly enough you can have them both open.
