Mac as an external device running virtual instruments
I've just upgraded to a G5. I still own my G4. I'm running lots of VIs. I'd like to be able to set up the G4 to run some of these .. to split the load.
I understand that I need to have a MIDI interface on each machine. I've been told I need lightpipe to get the audio from the external to the main machine.
Does anyone here have experience with this type of setup?
If so, I'm wondering if my two legacy pieces, the MIDI Timepiece II and the 2408 mk 1, will be useful in this setup.
I.e., are there adapters that will allow me to use the MTP II, which is serial, with the G4 (I guess firewire or USB)? And will the lightpipe on the 2408 Mk 1 do the job .. is it in any way different/inferior to how lightpipe is handled now?
Tx.
--j
Tx.
--j
even if you found a serial card for your g4, there is no support by motu for serial MIDI interfaces with coremidi on os x. you'd have to find a serial card or usb-serial adapter manufacturer that provides os x MIDI i/o drivers for their product.
you could network your MTP II to a newer MTP AV USB if you'd like to continue using it.
- emulatorloo
Re: Mac as an external device running virtual instruments
Judy -- look at stealthport for your g4 if you decide to go that route w your MTP II. I am using a similar product w an Opcode Studio 4 interface. Works fine in Core MIDI setup and with DP (all you get is 8 MIDI ins and outs, none of the special features of the interface, which is good enough for me)judyhyman wrote:If so, I'm wondering if my two legacy pieces, the MIDI Timepiece II and the 2408 mk 1, will be useful in this setup.
http://www.geethree.com/stealth/index.html
Here's a link to the MIDI driver -- I think there is a read me that explains how it works included w the download:
http://www.geethree.com/downloads/stealthmidi.html
Thank you all. I'm gonna hang onto this old gear and see whether I can eventually make it all work ... I have no lightpipe on the 1224, which is my main interface so I'll need to upgrade that before moving forward on this.
In the meantime, my "new" (2004) G5 is doing beautifully handling a fistful and more VIs.
--j
--j
- emulatorloo
Re: Thanks!
Judy -- No need to get hung up on lightpipe. IMHO. I use a PC in a similar set-up --Mac running the sequencer, PC running gigastudio. I just take the digital out of my PC's sound card into my mixer. Or if that isn't convenient, I just take the analog outs of my PC's sound card into my mixer.judyhyman wrote:Thank you all. I'm gonna hang onto this old gear and see whether I can eventually make it all work ... I have no lightpipe on the 1224, which is my main interface so I'll need to upgrade that before moving forward on this.
--j
So no reason you couldn't take the analog or digital output out of your G4 MOTU interface into your G5 MOTU interfaces.
GOOD LUCK and have fun w the new g5
