LED metronome?
LED metronome?
I'm looking for a way to hook up some kind of LED blinker via USB to the metronome in DP. My project requires that the tempo be specified and controlled within DP--but I would rather see the beat on a blinker than listen to it with headphones. (I'm recording trombone, and headphones are a serious pain.)
It seems like the new metronome features in DP 5 might support some kind of blinker device that would work like this, but I can't find anything about it online. Anyone have an idea?
Byron
Byron
Re: LED metronome?
Have you ever tried following a blinking light?
http://www.midisolutions.com/prodrel.htm
http://www.MIDI-metronome.co.uk/
http://www.videopete.com/MIDI/
http://www.maxmidi.com/diy/metro/index.html
Yes, I had a metronome with a blink function that I used for practicing quiet passages. I never had to follow tempo changes, though for this project I know the tempo, and would only use the light to maintain absolute accuracy.
Alternatively, does anyone know of a mono earpiece that doesn't touch or cover the inner ear? It's the physical contact that complicates tone production on a brass instrument.
- hearttimes
- Spikey Horse
DP5 visual click info here:
http://www.motu.com/products/software/d ... click.html
I've not tried it yet myself ....
- tommymandel
Yes, as the Horse points out (a pointing horse?!) the new QuickTime features in DP5 allow for Punches and Flutters. I think that's what you are looking for. You might have to create a dummy Quicktime movie to have them work.(?)
This (from the DP5 hype) seems remarkably vague:
"the visual click...flashes...on an external video screen (via external hardware triggered by DP5)."
Anyone know where to find the actual meaning of "external hardware"?
Hm, I bet I can get a MIDI device to blink with the metronome signal, since there won't be any other MIDI signals going on. Hadn't thought of that.
- tommymandel
I got it to work. In Preferences, you have to turn it on in 2 or 3 places:
1. Play And Record/ Click: Type of Click: Visual Punches (output should be Quick Time movie overlay (or you can route it to another video source in the Movie's mini-menu)
2. Play and Record/ Countoff/Countoff Visuals Output: Quick Time movie overlay
Visuals: Punches in sync with click
Warning Streamer before Countoff (if you want that...)
3. Play and Record/ Film Scoring Events: Generate Punches, etc (in Quick Time movie overlay)
that worked for me. I just chose a movie of my girlfriend's cat and dog sparring, and a big colored dot flashed on it in time with the click.
