Merged soundbites disappear
simul
Post by simul »
So, I've been using DP since DP4, almost 20 years! but this never happened to me, and it started a while ago, let's say around when I upgraded to DP11. I was recording some vocals today, and I had quite a lot of soundbites in various tracks (not that much honestly... let's say 7-8 tracks of vocals, and around 30/40 different takes on different soundbites for the song). As I always do, since forever, when we finished tracking, I simply merged the 8 tracks. right after that I cleaned the unused soundbites (removed, NOT deleted) and right after that, I flushed the undo history to clean the session and make it lighter. I've been doing this since forever, but lately, 1 or 2 of those merged files simply disappeared. I did NOTHING but the merged soundbites became unavailable and when I checked the audio files folder, that merged file simply wasn't there. When it happened the first time, I thought I did something wrong and blamed myself only. but now it's been quite a few times, and it's really frustrating, even more since it seems random. I managed to open an automatic autosave version and luckily saved the performance, but I really would like to understand why this is happening. I tried to write to Motu but they asked me how to replicate the behaviour and I didn't manage to succeed in that.
anyone has an idea on why is this happening?
many thanks for your help.
EMRR
Re: Merged soundbites disappear
Post by EMRR »
There seems to be some failures with unused soundbites since dp11. I haven't had problems with remove, but delete has definitely nuked some non-selected soundbites. Back to dp4, I never had a problem using delete willy-nilly to clean up sessions. It's become habit for me to drag off a backup copy of anything new before using that tool since dp11. It's not unusual to occasionally have to drag some things back from the backup afterwards.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
simul
Post by simul »
I just discovered after a few tests, that I now can replicate the issue. so basically if I merge a portion, then remove unused soundbites, then flush undo history and right after that I temporarily open another app (so let's say, I open finder, or I switch to safari, or any other app) and then come back to DP, that merged file won't exist anymore. So weird.
I never delete recordings, so haven't experienced the same phenomenon, but I have noticed that, on occasion, a group of soundbites will refuse to merge... select the bites, merge, and I get a blank waveform. Undo, and all is well again. Don't recall exactly how I got around this; maybe just duplicate the track, then merge.
This has only happened to me a couple of times, but may be related to your recent experience.
It would be lovely if you set up a MOTU Tech Note on this; feel free to report my experience if you do.
HC Markus
https://rbohemia.com
HCMarkus wrote: Mon Feb 24, 2025 3:22 pm I never delete recordings, so haven't experienced the same phenomenon, but I have noticed that, on occasion, a group of soundbites will refuse to merge... select the bites, merge, and I get a blank waveform. Undo, and all is well again. Don't recall exactly how I got around this; maybe just duplicate the track, then merge.
I've had the same experience. The one time my tracks wouldn't merge, I saw the problem and corrected it. Unfortunately, I no longer recall the details. :oops:
simul
Post by simul »
I'll set up a Motu Tech Link and will keep you updated.
thanks.
