828es not working properly after Win 11 did an update...
vonbleak
Post by vonbleak »
Hi guys,
So i recently did a clean install of Windows 11 and everything went fine... All of my audio software (Cubase Pro 10.5) and my 828es was working fine and all was good...
That was until a couple of days ago when windows did an update - now things are not so good lol... While windows and motu discovery still detects the motu and even cubase can 'see' the motu driver, however so sound or metering is coming out of the motu...
I had a similar issue in Win10 when i first got the 828es and it turned out to be a missing driver in Device manager - so thats where i looked - however there are no issues or missing drivers in Device Manager, and like i said, before this windows update everything was just fine...
Is anyone else facing similar issues...? And has anyone found a way to fix it...? Im hoping things will be sorted out in the next windows update but i really dont want to have to wait for that if possible...
Thanks for any help/info...
V :mrgreen:
[EDIT]
So windows has had a few more updates... I updated my motherboard bios and several of the motherboard drivers/utilities... ive reinstalled the latest Motu drivers... nothing has changed...
Windows and Motu discovery detects and can use the 828es and on the mix window i can see the talkback mic getting level but there is no playback (metering or audio)... Cubase can 'see' the motu driver but again there is no playback or metering... This is a clean install of win11 (after formatting my drives) and there are no issues/conflicts in device manager... Its very frustrating as when i first installed win11 everything was working fine, and i just dont get it... :shake:
vonbleak
Re: 828es not working properly after Win 11 did an update...
Post by vonbleak »
(Bump)
Has no one run into anything like this...? Im not too worried as im pretty sure it all works with USB3 but i spent money on a dedicated thunderbolt card so it would be nice if it all worked like it used to haha... 8)
Did you check the 828ES driver for updates at MOTU.com?
Techlink to MOTU is your friend here. MOTU is super responsive these days!
vonbleak
Post by vonbleak »
Yeah i have the latest drivers and firmware... :mrgreen:
dbmcclain
Post by dbmcclain »
Microsoft just did an update yesterday, 12/15/24, and all of a sudden some of my old software began working again. The MME drivers for my old 828mk3 hybrid now work as they did under Win7. The alternative until now was to use the MOTU ASIO drivers.
However... I now cannot install a newer 828es on my Win11 system. The install generates all the software, does a reboot, and then complains that the USB port connection failed and the device may be damaged.
Well, no. Because I just reattached the 828es to my M1 iMac, and it works just fine over there.
So, let's see... Win/11 was released in October 2021. Only yesterday do the MME drivers now work for my 828mkIII hybrid/USB. That's more than 3 years I would have suffered under Win/11. Glad I stayed on Win/7 until last week. I spent several days pulling out my hair trying to figure out workarounds, and just on a whim, I tried again yesterday after M$ did the Win/11 update. And now they work! Just like in Win/7.
But bad news on the MOTU 828es.
Also, Win/11 badly needs something like the Mac Aggregate devices where you can mix several different audio interfaces into one aggregate interface. It is impossible under Win/11 to read from one device and output to another not in the same physical interface. C'mon Microsoft!! Sheesh!!
dbmcclain
Post by dbmcclain »
Windows/11 Home, version 24H2, 12/15/24.
