The free VI's/plugs list.
Techivation T-Saturator - FREE
https://techivation.com/t-saturator/
T-Saturator is a smart level-independent saturation plug-in that gives you precise control over your track’s tone and character. Whether you’re looking for subtle warmth, enhanced dynamic range, or screaming distortion, T-Saturator will get you there with ease.
NESS Spatialization
I have no experience with this, but perhaps someone does. It looks similar to some plugs by Dear Reality, but those are really expensive.
https://ness-apg.com/
EDIT: apparently requires Java to run certain functions.
LOTUS SOUND AUDIO Ocean Plate Reverb - FREE
https://www.patreon.com/posts/ocean-plate-100710016
The YouTube video doesn't really have any audio examples. You can download it and try it out. Also keep in mind that developer doesn't seem to have a proper installer so you have to drag the .component file into your Components folder. This will result in the plug being "quarantined" and it wont pass validation. So prior to launch DP you will have to fix this issue using Terminal as described in this post.
OCEAN PLATE : Analog warmth, limitless creativity !
May 17
Introducing OCEAN PLATE 🌊 – the epitome of warmth, depth, and sonic excellence in the realm of digital audio processing. Crafted meticulously from a stunning analog device renowned for its unparalleled sonic character, Ocean Plate reverb plugin takes your audio to breathtaking depths, enveloping it in lush, immersive ambiance reminiscent of vast, shimmering oceans !
With its rich, warm sound, Ocean Plate is not just a tool ; it's an experience. Whether you're producing music, mixing tracks or designing soundscapes, this plugin infuses your creations with an unmistakable analog charm that sets them apart.
But Ocean Plate isn't just about reverb ; it's a complete sonic sculptor. Featuring a meticulously designed EQ section, you have total control over shaping your sound to perfection. Whether you're dialing in subtle enhancements or completely transforming the character of your audio, Ocean Plate empowers you to achieve your sonic vision effortlessly.
Ocean Plate brings the unmatched quality of analog reverbs within reach of every producer, musician, and sound designer.
Free Mastering the Mix Limiter plugin - need Instagram Account
Just go to this post: https://www.instagram.com/reel/C7zr0d1y21Q/
Leave a comment that just says "Limiter" and you'll get a DM with download and license info apparently.
Mastering the Mix EXPOSE2 - FREE at Plugin Boutique
No idea how long this will last. You have to go to Plugin Boutique and get it there and then use the code EXPB100 at checkout.
It's an app that you use to analyze final mixes and detect any issues, and more. Here's the link at Plugin Boutique:
https://www.pluginboutique.com/products/7908-EXPOSE-2
Also more info on the app here:
https://www.masteringthemix.com/products/expose-2
Here's the direct link to the PDF manual for EXPOSE 2 at Plugin Boutique. Might be helpful. Heck, it's free (for now)... grab it and THEN figure out if you can use it.
Free "Inflator" style plugin
Read about this on another forum. Someone commented it wasn't half bad. Might be worth checking out:
https://github.com/Kiriki-liszt/JS_Infl ... tag/v2.0.0
UPDATE: Ignore this... it's a bust. Even after you use Terminal to remove quarantine, AU fails exam and VST3 loads, but doesn't seem to do anything.
