Exactly..... which I guess just isn't going to happen as of DP7.2Dan Worley wrote:I think he means he'd like to see something for routing Sends on selected tracks like the way Audio Assignments works for assigning I/Os.
c-ya,
Dan Worley
bus multiple tracks at the same time?
Re: bus multiple tracks at the same time?
At the studio: 2" Sony/MCI 24 Track, 36x24 Neotek IIIC, Modest rack and mic selection, PTLE 7.4, 002R, Apogee AD8000, PPC Mac 2.7Ghz + 4GB Ram, OSX 10.4.9
Check out my completely out of date studio website: http://www.mysteriousredx.com" onclick="window.open(this.href);return false;
At Home: Intel iMac dual 3.06Ghz + 4GB Ram, OSX 10.6.2, DP7.12, Logic 9.1.1, Numerology 2.3
Did this get fixed for DP8?
This has annoyed me for a very long time. Audio Assignments is so easy, couldn't they have the same thing for sends?
I'd like to know before buying DP8.
No, the Audio Assignments window still does not offer the option of assigning sends.
This is not a 'fix', since it's never been a feature.
Join the club and submit a feature request at the MOTU suggestion box! The more of us that ask, the better.
http://www.motu.com/other/feedback/suggestions
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 14.5
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
Yes, I've submitted... no sign of it happening.BobK wrote:No, the Audio Assignments window still does not offer the option of assigning sends.
- FMiguelez
In the mean time, what's wrong with dragging and dropping the sends in the mixer, again? It's quite fast, even for multiple tracks.
There's nothing wrong with that, it just takes more time that doing it at once. I would think that even just assigning the sends of 48 tracks to the same bus at once could be implemented. That would take a lot less time than doing it 48 times... right?FMiguelez wrote:In the mean time, what's wrong with dragging and dropping the sends in the mixer, again? It's quite fast, even for multiple tracks.
- FMiguelez
You're right.HarmonicMotion wrote:There's nothing wrong with that, it just takes more time that doing it at once. I would think that even just assigning the sends of 48 tracks to the same bus at once could be implemented. That would take a lot less time than doing it 48 times... right?FMiguelez wrote:In the mean time, what's wrong with dragging and dropping the sends in the mixer, again? It's quite fast, even for multiple tracks.
It would be so much better if MOTU included the send assignments in the Audio Assignments window. Definitely.
My point was that, for now, at least they gave us the ability to drag and drop them, which totally beats selecting from impossibly long lists, like before DP8. This may indicate they are not planning on including them in the previously mentioned window any time soon.
I'm reviving this thread 10 years later!
I was just trying to find a way to mass-assign Sends from audio tracks to the same Bus. I couldn't find anything in the DP 11 manual to this effect. Is it still not possible?
(I was hoping that grouping the tracks then mass-assigning a send would work, just as it does for changing takes etc, but it does not...)...
Main SYS: 12-Core New Mac Pro (Dec 2013), 64GB RAM, OS10.10, Apollo Quad Interface, 3xSSD work/sound drives in TB Enclosure, UAD Plugs, DP, VE PRO, All NI, All Spectrasonics, many libraries, VIs etc.
2nd SYS: Intel 8-Core Mac Pro (2007), 28GB RAM, OS10.7, MOTU PCI 424, 2408 interfaces (4), DP8.07, VE PRO, All NI, All Spectrasonics, many libraries, VIs etc.
2 Mac Minis (2011): Dual Quad, 16GB RAM running VE Pro, various libraries in Kontakt, G-Player, UVI.
What you CAN do is set one to the output you want, then option-drag that to another track, and another, ad nauseum.
DP 11.32, 2020 M1 Mac Mini [9,1] (16 Gig RAM), Mac Pro 3GHz 8 core [6,1] (16 Gig RAM), OS 14.5/11.6.2, Lynx Aurora (n) 8tb, MOTU 8pre-es, MOTU M6, MOTU 828, Apogee Rosetta 800, UAD-2 Satellite, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
Aha! Much quicker. Thank you so much! ![Smile :)](./images/smilies/icon_smile.gif)
Sorry, no access to DP at the moment, so going from memory, but doesn’t the Audio Assign command do it?
Or selecting all the tracks holding one of the mod keys (Alt?) and assigning one of them, affects all those selected?
