The free VI's/plugs list.
Re: The free VI's/plugs list.
I bought a library not too long ago for contact that apparently used the actual tapes that 10cc used in the studio. It wasn't expensive. I have to see if I can find it.
Behringer has a new free VI out. Be forewarned their site is jacked up right now so you may have problems registering the free license, but you can at least download it. I don’t know if it works in demo mode for a while or what. I haven’t installed it yet.
https://plugins.musictribe.com/behringer/0723-AAD
I even made some NKS support files for it, attached. Be warned. No audio previews or tagging.
Behringer_Vintage_NKS_Files.zip
(752.54 KiB) Downloaded 32 times
DDMF New "Endless" Reverb - FREE
Just got an email about this. You can get it here:
https://ddmf.eu/freeware/
Waves Kramer HLS Channel FREE
This one has been a freebie a few times off and on. Here's another chance to get it... Limited Time
https://www.waves.com/account/free-kram ... ducersblog
Bobbyd
Re: Free AudioBro SILVER Kontakt Library
Post by Bobbyd »
James Steele wrote: Mon Apr 01, 2024 1:25 am Requires the full version of Kontakt
https://audiobro.com/SILVER/
Okay... I just installed and this is pretty cool for FREE... plus has full NKS support with previews.
I could have saved a lot of time if I knew the download only works with Native Access 2. And Native Access 2 doesn't work with Mojave. Rant over
iMac 27" 3.6 i9 2019 OS 10.14.4 40Gb RAM, DP 10.13 & 11.11
Mac Mini M1 2020, OS 12.4, 8GB RAM - DP 11.11 - Komplete Kontrol A49
Analog Obsession ATONE Channel Strip - FREE
https://www.production-expert.com/produ ... sion-atone
Sorry. I try. I don’t have an Intel system anymore so wasn’t aware of those issues.
Native Access 2 requires macOS 11 Big Sur or later.
Mastering the Mix LEVELS - FREE
Limited time... here's where you can read some info about the plugin:
https://www.masteringthemix.com/products/levels
Here's the link to follow to get it free. You will need to provide an email address but you can always unsub later if you wish.
https://sowl.co/s/bpQfXE
Crow Hill Demon Drop - Circuit Drums - FREE for 23 more hours
https://thecrowhillcompany.com/demon-drop-001/
Looks like if you're already on the email list or signed in you'll see a dowload button, else you'll see a form to join their email list go get access.
Demon Drop #001
Circuit Drums
A rarefied collection of electronic drums created from analogue and vintage modular sources, processed through classic vintage equipment, housed in an extraordinary interface designed to dial-up the demon in your drums.
Kompose Audio Arcturus Kontakt Instrument - FREE
This one requires full version of Konakt and is FREE, but you have to "purchase" the free instrument at Kompose Audio's site, so I guess they'll get an email. They'll send you a code which you redeem and then download with Pulse Downloader. Honestly it sounds pretty good. Basically the ethereal sustainy pad kind of thing.
https://komposeaudio.com/products/kompo ... o-arcturus
DH Plugins BASS-FACE - Free for limited time
Not sure how long this will be free, but it is for now: https://dhplugins.com/bass-face/
Small Plug-In, Big Sound… BASS-FACE is a ‘One-Knob’ style multi-effect plug-in designed to add presence and distortion to your sound. With 3 modes to select from, each increasing in drive and presence, BASS-FACE can add a gentle lift or face-melting heat to whatever you feed it.
A Simple interface and HUGE sound, BASS-FACE is designed as an enhancer / drive unit, processing several effects to add character, drive, width, modulation and presence to your sounds.
TYPE 1 – Gentle Presence, Space and Subtle Modulation
TYPE 2 – Saturation, Presence, Space and Subtle Modulation
TYPE 3 – Drive, Presence and Subtle Modulation
CLIP – Adds a no-frills hard clipper to the end of the signal chain
XTRA – Boosts the Spacial and Modulation effects
T-RackS Quad Image - FREE for Limited Time
They only have 25,000 licenses to give away and that started today, so head over there if you think you want to grab a copy for FREE (if there are some left).
Sixth Sample: SpotOn vocal tuner (and others)
I just saw a little demo for a free, simple, and pretty effective vocal tuner called Spoton.
https://sixthsample.com/spoton/
Could be useful when one just wants a simple "touch-up" tuning.
There are other free and pay plugins on this developer's site, including dynamics, distortion, filters, also, an interesting looking "Noise-Assisted Stereo Enhancer". (looks like all permanent licenses).
https://sixthsample.com/plugins/
Get GForce Access FREE at PB with code (EXPIRED NOW)
https://www.pluginboutique.com/products/12022-AXXESS
Add it to cart... skip the free gift because you can't have one if you use the code to get AXXESS free. Check out as normal and use the code xxw5cxly to drop the price from $83 or so down to $0!
FYI... not sure where the code came from. Found it on a site, but it worked for me although fulfillment isn't immediate. I went into my Plugin Boutique account area and it says I'll get an email with my serial number at some point.
UPDATE: Unfortunately, the code is no longer valid.
UPDATE 2: Some are saying the code is working again. Seems to be off and on. You might give it a try... no guarantees.
