Motu M2 Issue with Siri and Dictation - RESOLVED
Re: Motu M2 Issue with Siri and Dictaion
nireldesign wrote: Mon Apr 29, 2024 11:37 am thanks
what can be done here?
FYI, after you attach a graphic, try to use the "place inline" button so it's more neatly embedded in the post if you can.
nireldesign
Post by nireldesign »
James Steele wrote: Mon Apr 29, 2024 12:24 pm
OkI'll try to remember this :)
nireldesign
stubbsonic wrote: Mon Apr 29, 2024 11:46 am Yea, I think that was a red herring.
My interface shows all the faders zeroed out, because Core Audio does not have control over those levels-- which are handled by the device and it's mixer/config panel.
But that doesn't mean that the input is not receiving signal-- just means CoreAudio can't control it.
Just disregard this.
I use software from Rogue Amoeba called Loopback ($100 USD) which lets me create virtual input and output devices with combinations of various signal routings-- and those have volume controls.
OK then my issue can't be solved...?
CharlzS
Post by CharlzS »
I just tried Dictation with an M4 and 2023 MB Air on Sonoma without issue. Do you have Dictation configured properly in Keyboard Settings? It only works with a microphone connected to In 1, but that's probably because it's expecting a mono source and just defaults to the first available stream for a device. Something like that . . . Siri appears to work with either In 1 or 2.
DP 11.31 PT 2024.3 VEP 7.x with various VIs
nireldesign wrote: Mon Apr 29, 2024 1:12 pm OK then my issue can't be solved...?
Nah. I'm pretty confident it CAN be solved. I was just barking up the wrong tree and adding noise.
nireldesign
CharlzS wrote: Mon Apr 29, 2024 2:48 pm I just tried Dictation with an M4 and 2023 MB Air on Sonoma without issue. Do you have Dictation configured properly in Keyboard Settings? It only works with a microphone connected to In 1, but that's probably because it's expecting a mono source and just defaults to the first available stream for a device. Something like that . . . Siri appears to work with either In 1 or 2.
Thank your for your kind reply
You're magician!
I've finally found out that it'll work just with input #1... :D
(It won't work with input#2)
Re: Motu M2 Issue with Siri and Dictation - RESOLVED
Glad to see this resolved. I’ve sold my M2 and was arranging to borrow back my M4 today to test this. It hadn’t occurred to me that I use Channel 1 of my AIR 192|14 for System audio.
We learn new things all the time (looking for that face palm emoji).
nireldesign
mikehalloran wrote: Tue Apr 30, 2024 9:01 am Glad to see this resolved. I’ve sold my M2 and was arranging to borrow back my M4 today to test this. It hadn’t occurred to me that I use Channel 1 of my my AIR 192|14 for System audio.
Many thanks Mike!
