James Steele wrote: ↑Mon Mar 18, 2024 9:20 pm
Hey Mike... I'm still deciding if I'm going to go for this or not, but as an current ARC3 owner if I can get a discount I might be interesting in buying your spare if its the MEMS mic? I have the older style mic and it's my impression the MEMS gives more accurate results?
I could not get IKM to sell me the box without the mic. When I posted that Peter was wrong and attached a copy of my receipt to prove it, he deleted the post and banned me for 30 days. That idiot does not understand that we, the customers, are the boss, not he.
I was able to use Jam Points and an introductory offer to purchase the box with microphone for less than the upgrade that I qualified for — that's why I have a spare MEMS microphone.
I am curious what your impressions are of the hardware are? I guess the only downside I see is for me to use it it's going to add another A>D and D>A conversion prior to going to the monitors. Still I do like the idea of a hardware solution rather than using a plugin, and from what I understand this is the first of that kind priced within the reach of mere mortals.
I have it set up and am impressed.
When I hooked it up and opened ARC 4 Analysis.app, it did an immediate Firmware update. You can access the manual from within the GUI, the IK Project Manager or online. The manual is difficult to search because of the different languages. Fortunately, it's not too long.
Once I created the Profile and saved it to the box, it's like old Ron Popeil —
"Set it and forget it." The box adds about 3dB engaged so, when I put it into bypass mode, I have to compensate with the volume on my Radial MC3 box.
None is one of the included Profiles (switchable in ARC.app) if I want to keep the box and its volume boost engaged.
I could install it before my controller and use the ARC 4 App to switch profiles and run my other monitors. I can also use the ARC4 plug-in on the Master bus of a DP project and switch monitor pairs while either bypassing the box or selecting
None as a profile.
To be clear, ARC 4.app is not needed except when switching Profiles or viewing the GUI (same view as the plug-in).
My studio hated the ARC 3 plug-in. This is much, much better. Set up is easy in a separate app, ARC 4 Analysis.app. You store the setting(s) in a Documents file available to both the plug-in and the app.
My setup is not ideal and requires a couple new cables due to space issues. When I have that resolved, I will re-measure with and without my subwoofer engaged and see what works best. My MC3 lets me engage/disengage and adjust the volume of the Sub without making me crawl under the desk.
The attached graphic shows the Before (med and light green) and After (yellow/orange) against the ideal (white). This is done with the Sub disengaged. Anyway, notice how ARC 4 tamed a 12dB hump at 50Hz and flattened out a drop from 9K–20K. Both are notable improvements. Adding the Sub back in put it where I liked it (I'll explain later how I calibrate a Sub so that I can trust it).
- Screenshot 2024-07-04 at 2.37.01 PM.png (467.26 KiB) Viewed 4155 times
Oh yea, this stays!
At some point soon, I'll A/B this against the Slate VSX — bought that after being so disappointed by ARC 3.
