Meter bridge VS Mixer meters
Hi, anybody knows why in the meter bridge page the max level in 0dB and in the mixer page is +6dB ?
Example, I play a signal at 0dB, in the meter bridge I see 0dB, but in the channel meter is +6dB.
Is there a way to change the scale in the mixer avoiding to the meter bridge scale?
Re: Meter bridge VS Mixer meters
I have also remarked on that in the past and would like that option to set it to match the meter bridge!
http://www.bfdmusic.com
Mac Studio Ultra, 64 gigs RAM, OSX 12.7.5, DP 11.3, UAD2 thunderbolt satellite octo, Apogee Symphony IO MK2 TB
Does the "Scale" control on the meter bridge (p. 908) not do what you want?
828x MacOS 14.5 M1 Studio Max 1TB 64G DP11.32
?? You can drag the top down so it peaks at less than 0db but I don't think you can drag it up to 6db. Can you get it 6db?
Anyway, my assumption has always been that these are not the same meter. If they are, then yes, they ought to have the same scale.
You are correct, one can only drag it down.
My understanding has always been that the scale in the mixer is for the fader and not for the level bar graph. I could be wrong.
Or maybe the discrepancy has to do with panning and pan law stuff. I don't know. All I know is I never use the bar graph in the mixer if I'm looking for numbers. I use the meter bridge or a meter insert.
DP 11.32, 2020 M1 Mac Mini [9,1] (16 Gig RAM), Mac Pro 3GHz 8 core [6,1] (16 Gig RAM), OS 14.5/11.6.2, Lynx Aurora (n) 8tb, MOTU 8pre-es, MOTU M6, MOTU 828, Apogee Rosetta 800, UAD-2 Satellite, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
