I'm having an issue with DP10 getting instantly glitchy at almost exactly 6 hours into a session. Perhaps an overheat thing? I run an 828X and its near bulletproof up until that 6 hour mark. If i restart the computer and power cycle the interface its fine.
(on rare occasions I'll need to repeat the process a second time)
Anyone ever deal with this?
It first happened when I was running two 828x units simultaneously but now it even happens when only one is connected.
DP 10 stutter/freakout after (or almost exactly) 6 hours. Overheat?
Re: DP 10 stutter/freakout after (or almost exactly) 6 hours. Overheat?
Yes, on an older 828, especially on a warm day. I added space around it in the rack and that helped, but even then, on a hot day it died after a few hours. I’d had it for about 15 years at that point so just replaced it.
detroitdiesel wrote: ↑Mon Nov 06, 2023 6:12 am I'm having an issue with DP10 getting instantly glitchy at almost exactly 6 hours into a session. Perhaps an overheat thing? I run an 828X and its near bulletproof up until that 6 hour mark. If i restart the computer and power cycle the interface its fine.
You may have two things going on. Your workarounds solve both temporarily but don't isolate either one.
Rebooting the computer dumps any RAM caches. Cycling the 828x cools it down for awhile.
Since we know nothing else about your setup, there's not much else to add. Please include your OS and build as well as the version of DP 10. Also let us know your hardware including how much RAM is installed and if you have any other apps active while using DP including a browser.
Thanks for the replies. I'm running DP 10.13 on a 2.8 intel i5 with 16G of RAM. The same issue happened in last nights session at almost the 6 hour mark. A quick restart solves the issue. I don't let it cool. works fine after that.
Very strange indeed
Thanks, DD
Very strange indeed
Thanks, DD
This is a classic example of not enough free RAM. Rebooting clears the cache and frees RAM being used by other apps.detroitdiesel wrote: ↑Wed Nov 08, 2023 6:57 am Thanks for the replies. I'm running DP 10.13 on a 2.8 intel i5 with 16G of RAM. The same issue happened in last nights session at almost the 6 hour mark. A quick restart solves the issue. I don't let it cool. works fine after that.
Very strange indeed
Thanks, DD
You can clear the RAM cache by opening Terminal.app and entering the following command followed by the Return or Enter key:
sudo purge
Enter your Admin password when prompted.
This should help. Don’t cycle the 828x.
Memory leaks are the bane of all software. Developers go after them like a big game of Whack-A-Mole Here's what you can do. You didn't say what OS and hardware (I did ask) so I'll make some guesses.
If RAM is already maxed out, nothing you can do about that but, if not, add more. I just spent four days doing a clean install of IKM's Total Studio Max 4 on my 2012 MacBook Pro test machine (16GB is the max RAM) because the Product Manager kept freezing. I'd run sudo purge or reboot to get it going again (never froze on my new Studio with 192GB AM — go figure).
Run the latest version of the macOS you can. Check for any security updates etc.
Reboot before a DP session and do not have any other apps running — especially a browser. Web pages are a major source of memory leaks.
Download and reinstall DP 10.13. It's possible that the build at motu.com is later than the one you have installed.
Make sure that all your plug-ins and VIs are up to date. Again, memory leaks are the normal bug fix in the latest version of anything.
Perform a Safe Boot by shutting down and holding the Shift key when you boot your Mac. Enter your Admin password when prompted. After your desktop icons rebuild, reboot normally. This resets your System caches and pathways to default. It does not touch your Users caches.
Delete the Users/(user)/Library/Preferences cache for DP so thast it can rebuild. This loads every time you launch DP. Here's a recent thread on this. It should be done once a year or so.
https://www.motunation.com/forum/viewto ... 2F#p606565
