Crashing DP 11.23 & Kontakt 7.6.1
midilance
Post by midilance »
Is anyone else experiencing this? Both of these updates happened recently.
Mac Studio m2 Max // OS 14.3.1 // DP 11.3.1 // MotU Ultralite mk4 // Komplete Ultimate 14 // Arturia V Collection 9 // Korg Collection // Stylus RMX 1.8 // Omnisphere 2.6.2c // Scarbee Keys and Basses // T-Racks 5 // Amplitube 5 // BFD3 // Blue3 // PolyM //
zounds
Re: Crashing DP 11.23 & Kontakt 7.6.1
Post by zounds »
Am still on 11.22 and 7.5.2, but heavily reliant on DP and Kontakt, so following...
I've posted about this several times and I'm still on K7.6.0. MOTU has confirmed this through a
techlink.
hammerman
Post by hammerman »
Yes, I have the same issue. It's Kontakt 7. NO crashing when I'm not using Kontakt.
M2 Mac Studio Ultra - 64 GB RAM - Sonoma - DP 11
fdco
Post by fdco »
Same here. The problem is kontakt 7.6.1.
Reverting to 7.6.0 stopped the crashes for me.
Envoyé de mon iPhone en utilisant Tapatalk
Mac Book Pro M1 32gb -2TB,
Apogee Symphony Thunderbridge,
DP11, MTPAV, Linnstrument, Chapman Stick
hammerman
Post by hammerman »
How do you revert back?
Update: Just Googled and apparently same problem in a Logic forum.
I will try Time Machine...
hammerman wrote: Thu Oct 19, 2023 2:06 pm How do you revert back?
Posted by Evil Dragon at VIC:
https://drive.google.com/drive/folders/ ... wN8Alyxmo3
midilance
Post by midilance »
You know Native Instruments must be burning the midnight oil for this. It completely stopped my ability to use my Komplete sounds.
cuttime wrote: Thu Oct 19, 2023 2:24 pm
Awesome! Thank you. I'm not crashing, but I'm getting CPU spikes in lots of projects and I've been chasing my tail trying to figure out what is causing it. It may be the new Kontakt 7.
midilance wrote: Thu Oct 19, 2023 5:04 pm You know Native Instruments must be burning the midnight oil for this. It completely stopped my ability to use my Komplete sounds.
I sure hope so!!!
Just in case anyone is suspicious of Google Drive files, Evil Dragon (Mario Krušelj) works for NI and is absolutely trusted in my book.
hammerman
Post by hammerman »
James, I've been having tons of CPU spikes and weirdness so it must be Contact because it ain't happening with 7.6.0!
It made my Mac Studio Ultra feel like a sputtering old computer.
I’m still having spikes. Or was. Long story short I tried to do a number of things including installing macOS 14.1 beta which didn’t help, then I tried to roll back which screwed something else up, so now I have to wipe my boot volume and reinstall the OS and then install the apps and everything from a time machine back up. And I have to leave on a trip for three days tomorrow so I’m having to leave my Mac in utter disarray while I’m gone which I hate.
I will say this though. There is a practical case to be made for setting up separate volumes on the same internal SSD. Because it was set up this way, I was able to erase and reformat my boot volume without touching the other volume which contains my DP projects. Had I simply put my DP projects in a folder rather than setting up a separate volume, I couldn’t have reformatted my boot volume without erasing my DP projects as well.
James Steele wrote: Fri Oct 20, 2023 12:56 amI will say this though. There is a practical case to be made for setting up separate volumes on the same internal SSD. Because it was set up this way, I was able to erase and reformat my boot volume without touching the other volume which contains my DP projects. Had I simply put my DP projects in a folder rather than setting up a separate volume, I couldn’t have reformatted my boot volume without erasing my DP projects as well.
This.
This.
Yep! To my mind, this settles the debate. I can’t imagine the hassle I’d be dealing with otherwise.
